Momentary (but consistent) CPU lock-ups when manually touching-off
5 years 8 months ago #198528 by ljkenny
Any idea why one (of my 4 [with the 4th core set with isolcpus]) CPU maxes out during manual touch-off setting?
Gmoccapy consistently becomes unresponsive for ~30 secs every time X, Y or Z offset is set.
Is this a known behaviour or do I have something set-up incorrectly?
I also get a lock-up when loading a 8MB G-code file. Does 8MB really take that long to process?
What is so CPU intensive about setting touch-offs? And why only 1 CPU; isn't Gmoccapy multi-threaded?
Any help would be gratefully received.
5 years 8 months ago #198532 by robertspark
isolation of power supply required (complete isolation.... don't connect the and connections together) would be my suggestion
5 years 8 months ago #198533 by Hakan
The larger the g-code program is loaded, the longer the touchoff takes. Don't know why.
30 seconds sound a long time, many seconds for a long program anyways,
5 years 8 months ago #198565 by cmorley
Gmoccapy should honour these commands in the gcode:
linuxcnc.org/docs/2.8/html/gui/axis.html#axis:preview-control
If it's the loading of the large program that should help.
When you touch off linuxcnc must reload the program in the display.
It is not done in the background.
5 years 8 months ago #198574 by ljkenny
Not sure what you're trying to say @robertspark.
Ah okay, it makes sense about the larger program.
So long as it doesn't start locking up as I'm cutting, I guess I can live with it.
5 years 8 months ago #198578 by tommylight
Moderators: newbynobi, HansU
Time to create page: 0.160 seconds
