CCW dosen´t Work
2 years 2 months ago #306860 by Basti
CCW dosen´t Work was created by Basti
Hello everyone,
First of all, many thanks to the forum and the many helpful contributions. Thanks to you, I almost got an old Emcotourn 340 working again.
I just can't get the spindle's CCW to work.
With CW the control gives me everything.
With CCW, the spindle brack signal comes briefly and then signals that the spindle has reached speed. But nothing turns.the other signals don't come on either.
 Maybe someone can tell me what's wrong in the ini or hal. Thank you very much and best regards Sebastian
2 years 2 months ago #306862 by Aciera
Replied by Aciera on topic CCW dosen´t Work
Use the 'Halshow' tool and watch these signals when trying to run the spindle CCW:
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
Post a screenshot so we can have a look.
The following user(s) said Thank You: spumco, Basti
2 years 2 months ago #306863 by spumco
Replied by spumco on topic CCW dosen´t Work
Without getting in to hardware diagnostics, first thing I'd try is editing the INI file.
Change [SPINDLE]:
MAX_VELOCITY = 3000
To:
[code]MAX_FORWARD_VELOCITY =3000 MIN_FORWARD_VELOCITY =
MAX_REVERSE_VELOCITY =3000 MIN_REVERSE_VELOCITY =
[/code]
And see if that helps.  I assume you're using a 0-10v analog signal the the spindle motor VFD.  I suggest setting up a halshow watch list that includes all the spindle output signals/pins, including the output voltage to the VFD.
The following user(s) said Thank You: Aciera, Basti
2 years 2 months ago #306866 by spumco
You seem to be about 10 seconds ahead of every response I type!image missing /media/kunena/emoticons/smile.png
The following user(s) said Thank You: tommylight, Basti
2 years 2 months ago #306868 by Aciera
But your diagnostic seems more informed than mine.
The following user(s) said Thank You: tommylight, spumco, Basti
2 years 2 months ago - 2 years 2 months ago #306869 by PCW
Replied by PCW on topic CCW dosen´t Work
The spindle analog settings are for a -10V to +10V controlled spindle
If you have a 0 to +10V controlled spindle you will need to replace
with
net spindle-vel-cmd-rpm-abs => pid.s.command
and use a separate digital output to control the spindle direction
Last edit: 2 years 2 months ago by PCW.
Moderators: newbynobi, HansU
Time to create page: 0.298 seconds
