Update NativCAM
9 years 6 months ago #91238 by absolut15
Update NativCAM was created by absolut15
hello .
I have a problem with updating linuxcnc and nativecam.
everytime when i try to update linuxcnc together with NativeCam i have big problems to fix it to run both again.
my steps are :
master 2.8 source...
sudo apt-get update
sudo apt-get upgrade
after this when i run lcnc my Nativcam tab (i run it in a tab) doesn not work...
then i make a ...
git checkout master
git pull
sudo ./nondeb_setup.py c
then mostly all files are added...
./ncam.py -i /home/wws/linuxcnc/configs/Bohrwerk/Bohrwerk.ini c=mill
NativeCAM info:
inifile = /home/wws/linuxcnc/configs/Bohrwerk/Bohrwerk.ini
SYS_DIR = /home/wws/NativeCAM
NCAM_DIR = /home/wws/NativeCAM/
program = ./ncam.py
File "./ncam.py", line 4323, in <module>
ncam = NCam()
File "./ncam.py", line 1840, in __init__
self.update_user_tree(fromdirs, NCAM_DIR)
File "./ncam.py", line 1971, in update_user_tree
for f in os.listdir(src_dir) :
OSError: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/home/wws/NativeCAM/defaults/lathe'
after this NativeCam not work
i change to a tab:
EMBED_TAB_NAME = NativeCAM
the same result....
when i copy the Nativecam folder to /usr/lib/pymodules/python2.7/gladevcp/
normaly the ncam work but not the last days...
can someone help me please?
nice greedings
florian
9 years 6 months ago #91302 by absolut15
Replied by absolut15 on topic Update NativCAM
hi again.....
now it works again after i install and deinnstall ncam some times...
but the following error is now at the most mill subroutines..
G-Code error in ncam.ngc
Near line 173 of
/home/wws/nativecam/scripts/ncam.ngc
Named parameter #<_lead_out_fact> not defined
9 years 6 months ago #91538 by absolut15
hi ...
perhaps someone with the same problem can help this:
install the older release from github and it works again....
nice greedings
9 years 6 months ago #92237 by absolut15
i want say sorry for my stupi question..now i know how a deb package works...
lol
i build it and install it , and then its simple to config all for the first start.
only one problem is new now....
when i miling l a rectangel or somthing and i rotate it then i get an error:
Found an error!
The following information may be useful in troubleshooting:
File "/usr/lib/python2.7/dist-packages/hal_glib.py", line 386, in update
p,rel_p,dtg = self.get_position()
File "/usr/lib/python2.7/dist-packages/hal_glib.py", line 560, in get_position
t = math.radians(-self.stat.rotation_xy)
NameError: global name 'math' is not defined
pleas help me . because after this error gmoccapy freez
9 years 5 months ago #92776 by FernV
Replied by FernV on topic Update NativCAM
Hi Florian,
I was not aware of your problem until 2 days ago...
I just pushed some fixes and hope it will solve the problem
Regards
Fern
P.S I will push files for TT font engraving later today
9 years 5 months ago #92805 by absolut15
HI Fern!
it is monday and 7 am in the mornig ..normaly not a good time but you made it a lot better this time.
i make a new deb file and i install it . and alll works perfekt .
thanks a lot
florian
Time to create page: 0.360 seconds
