I realize I should clarify that I'm focusing on mills, but I realize that other readers would be interested in the same info for their lathe setup.
My overall question is: Is this analog signal the default means that PathPilot expects to use to control spindle speed and direction?
Following on: If yes, is it low end of voltage range is full speed reverse, mid point of range is 0 rpm and high end of range is full speed forward?
And related: PathPilot both has to interpret G code spindle speed/direction commands and (IIRC) displays spindle speed. On Tormach mills, what is the default means that this is handled, including how does PathPilot know which level the belt is on? I was looking at Tormach's schematic and I don't see an indication of an encoder or similar - but I may have missed it.
So, to the point: when using PathPilot on a non-Tormach setup, how do you get spindle RPM accurately back to PathPilot for display and G code interpretation?
