QtPyVCP Mill Touch Screen
7 years 7 months ago - 7 years 7 months ago #128817 by BigJohnT
After using my BP_Touch for a while on the mill I decided to change a few things up so I started from scratch and used the new VTK backplot which is way faster to render than gremlin is. Now I'm sort of a minimalist so I don't go for the flashy GUI's but that's all done with stylesheets or in the .qss file so it does not change the GUI to add style if one wants that.
The files
github.com/jethornton/mill_touch
The Docs
jethornton.github.io/mill_touch/index.html
Some screen shots
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-01.png
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-02.png
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-03.png
On this tab I'm using the new container with rules to disable everything in this tab until a tool is loaded
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-04.png
Now with a tool loaded I can set tool offsets for the current tool
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-05.png
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-06.png
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-07.png
image missing https://jethornton.github.io/mill_touch/_images/mill-touch-08.png
JT
Last edit: 7 years 7 months ago by BigJohnT.
The following user(s) said Thank You: biqut2, chimeno, tommylight, tivoi, KCJ, Leon82, silopolis
7 years 7 months ago #128838 by tommylight
7 years 7 months ago #128861 by Leon82
Replied by Leon82 on topic QtPyVCP Mill Touch Screen
Is that the same as the vtk backplot?
I didn't see vcp backplot in the widget list
7 years 7 months ago #128881 by BigJohnT
Replied by BigJohnT on topic QtPyVCP Mill Touch Screen
tommylight wrote: Elegantly beautiful ! Does it come in black? :)
You can have what ever color you want just change the color in the qss file :)
JT
The following user(s) said Thank You: tivoi
7 years 7 months ago #128882 by BigJohnT
Leon82 wrote: Is that the same as the vtk backplot?
Sorry, that was a typo it is VTK backplot
JT
The following user(s) said Thank You: Leon82
7 years 7 months ago #128901 by BigJohnT
Yes! I changed one word in the config.yml file and copied a dark qss to the ui directory.
JT
The following user(s) said Thank You: chimeno, tommylight, tivoi, emilvv, KCJ
Moderators: KCJ, Lcvette
Time to create page: 1.215 seconds
