[solved] Linuxcnc crashes when opening files
  • anfänger
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 1 month ago - 6 years 1 month ago #181660 by anfänger
I updates to linuxcnc 2.8 and the latest qtpyvcp and probe basic.
wie I open some files linuxcnc is shutting down with following error:
/usr/bin/linuxcnc: Zeile 896: 4065 Speicherzugriffsfehler $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS Shutting down and cleaning up LinuxCNC...
and when powering up I get a lot of error messages:
ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkShaderProgram.cxx, line 431 vtkShaderProgram (0x564f846c6500): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, 1.30, 1.00 ES, and 3.00 ES ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkShaderProgram.cxx, line 430 vtkShaderProgram (0x564f846c6500): 1: #version 150 2: #ifdef GL_ES 3: #if __VERSION__ == 300 4: #define attribute in 5: #define varying out 6: #endif // 300 7: #else // GL_ES 8: #define highp 9: #define mediump 10: #define lowp 11: #if __VERSION__ == 150 12: #define attribute in 13: #define varying out 14: #endif 15: #endif // GL_ES 16: 17: 18: /*========================================================================= 19: 20: Program: Visualization Toolkit 21: Module: vtkPolyDataVS.glsl 22: 23: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen 24: All rights reserved. 25: See Copyright.txt or http://www.kitware.com/Copyright.htm for details. 26: 27: This software is distributed WITHOUT ANY WARRANTY; without even 28: the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR 29: PURPOSE. See the above copyright notice for more information. 30: 31: =========================================================================*/ 32: 33: attribute vec4 vertexMC; 34: 35: // frag position in VC 36: //VTK::PositionVC::Dec 37: 38: // optional normal declaration 39: //VTK::Normal::Dec 40: 41: // extra lighting parameters 42: //VTK::Light::Dec 43: 44: // Texture coordinates 45: //VTK::TCoord::Dec 46: 47: // material property values 48: //VTK::Color::Dec 49: 50: // clipping plane vars 51: //VTK::Clip::Dec 52: 53: // camera and actor matrix values 54: uniform mat4 MCDCMatrix; 55: 56: // Apple Bug 57: //VTK::PrimID::Dec 58: 59: // Value raster 60: //VTK::ValuePass::Dec 61: 62: void main() 63: { 64: //VTK::Color::Impl 65: 66: //VTK::Normal::Impl 67: 68: //VTK::TCoord::Impl 69: 70: //VTK::Clip::Impl 71: 72: //VTK::PrimID::Impl 73: 74: gl_Position = MCDCMatrix * vertexMC; 75: 76: 77: //VTK::ValuePass::Impl 78: 79: //VTK::Light::Impl 80: } 81:
and some more which I don't get in the terminal because it is ti fast and are not in the log files
the is just following:
cat igor.log 2020-09-10 19:26:34,914 - qtpyvcp - INFO - Logging to /home/igor/linuxcnc/configs/IgorProbe/igor.log 2020-09-10 19:26:34,915 - qtpyvcp - INFO - QtPyVCP Version: v0.3.8 2020-09-10 19:26:35,379 - qtpyvcp.utilities.info - INFO - The machine has 3 axes and 3 joints 2020-09-10 19:26:35,379 - qtpyvcp.utilities.info - INFO - The Axis/Joint mapping is: 2020-09-10 19:26:35,379 - qtpyvcp.utilities.info - INFO - Axis X --> Joint 0 2020-09-10 19:26:35,379 - qtpyvcp.utilities.info - INFO - Axis Y --> Joint 1 2020-09-10 19:26:35,379 - qtpyvcp.utilities.info - INFO - Axis Z --> Joint 2 2020-09-10 19:26:35,575 - qtpyvcp - INFO - Loading global stylesheet: /home/igor/probe_basic/probe_basic/probe_basic.qss 2020-09-10 19:26:38,385 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.virtual-input.enable Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,386 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-grid Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,387 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-machine-bounds Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,387 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-machine-labels Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,388 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-machine-ticks Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,388 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-program-bounds Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,389 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-program-labels Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,389 - qtpyvcp.widgets.form_widgets.main_window - ERROR - Error binding menu action settings.backplot.show-program-ticks Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 134, in getMenuAction actions.bindWidget(menu_action, action_name) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget raise InvalidAction("Could not get action method: %s" % item) InvalidAction: Could not get action method: settings 2020-09-10 19:26:38,647 - qtpyvcp.app.launcher - INFO - Loading POSTGUI_HALFILE: /home/igor/linuxcnc/configs/IgorProbe/hallib/postgui.hal
Has anyone some ideas?
Thanks Patrick
File Name: Igor.ini
File Size:6.54 KB
Last edit: 6 years 1 month ago by anfänger.
  • anfänger
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 1 month ago - 6 years 1 month ago #181664 by anfänger
Replied by anfänger on topic Linuxcnc crashes when opening files
some of the errors in the beginning of power up come from filling the tool changer widget and and are a little odd cause the atc widget is filled as usual. But the VTK-Plot widget seems to miss
[qtpyvcp.app.launcher][CRITICAL] Unhandled exception in machine_actions.py line 425 (launcher.py:37) Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/actions/machine_actions.py", line 425, in set CMD.rapidrate(float(value) / 100) File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/hal/hal_qlib.py", line 112, in signal_handler self.exit() File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/hal/hal_qlib.py", line 109, in exit return self._comp.exit(*a, **kw) RuntimeError: Invalid operation on closed HAL component [qtpyvcp.plugins.notifications][ERROR] Error evaluating DEBUG expression: 'vcp.getWidget("dynatc").store_tool(1.000000, 1060.000000)' (notifications.py:146) Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/plugins/notifications.py", line 144, in timerEvent eval(exp, {"vcp": app}) File "<string>", line 1, in <module> File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/app/application.py", line 213, in getWidget raise AttributeError("Could not find widget with name: %s" % name) AttributeError: Could not find widget with name: dynatc [qtpyvcp.plugins.notifications][ERROR] Error evaluating DEBUG expression: 'vcp.getWidget("dynatc").store_tool(11.000000, 2001.000000)' (notifications.py:146) Traceback (most recent call last): File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/plugins/notifications.py", line 144, in timerEvent eval(exp, {"vcp": app}) File "<string>", line 1, in <module> File "/home/igor/.local/lib/python2.7/site-packages/qtpyvcp/app/application.py", line 213, in getWidget raise AttributeError("Could not find widget with name: %s" % name) AttributeError: Could not find widget with name: dynatc
6 years 1 month ago - 6 years 1 month ago #181705 by KCJ
Replied by KCJ on topic Linuxcnc crashes when opening files
Hello Patrick,
Those are really strange errors.
The VTK error looks to be a GL shading language version mismatch, I'm not sure how to fix that. It could be that installing the latest version of VTK will work. I will try to set up a test environment and experiment with that.
The raise InvalidAction("Could not get action method: %s" % item) are likely due to menu items defined in the GUI that are not set up in the YAML setting definitions. This is not a big deal, probably caused my mismatched QtPyVCP and ProbeBasic versions. This only affects the window menu items, some of which might not function correctly.
The other errors are really strange. Again I think caused by miss matched versions. Are you possibly running a really old version of ProbeBasic??
What is the output of qtpyvcp --info and probe_basic -v?
Cheers,
Kurt
Last edit: 6 years 1 month ago by KCJ.
  • anfänger
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 1 month ago #181717 by anfänger
Thats a bit odd I think I use the git versions of both but I get this:
qtpyvcp -v QtPyVCP v0.3.8 igor@igor:~$ probe_basic -v QtPyVCP v0.3.8, Probe Basic vv0.2.8+158.gdfd576e.dirty
in git I get for qtpyvcp:
v0.3.8-100-gc57bb925
I usually update by
git fetch --all git reset --hard origin/master pip install -e .
But I recycle my UI file cause I made a lot of changes to suite my machine.
Tanks for your help
6 years 1 month ago - 6 years 1 month ago #181726 by TurBoss
Replied by TurBoss on topic Linuxcnc crashes when opening files
Hello,
thanks for the report
could you please issue this command?
glxinfo | grep OpenGL
It will show the system GLSL version 1.50
from the error I can read
is the VTK from the repos or built from sources?
Last edit: 6 years 1 month ago by TurBoss.
6 years 1 month ago #181727 by TurBoss
have you changed your graphics card ?
  • anfänger
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 1 month ago - 6 years 1 month ago #181823 by anfänger
I changed only the apt repo to 2.8 linuxcnc and ran an update (all packages including the Debian ones maybe this was a mistake). No hardware changes
kernel: 4.9.0-13-rt-amd64
my apt sources
everything comes from the precompiled except some pythons modules I installed by pip and qtpyvcp, probe_basic and the hand wheel module
clx resulsts:
OpenGL vendor string: VMware, Inc. OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits) OpenGL version string: 3.0 Mesa 13.0.6 OpenGL shading language version string: 1.30 OpenGL context flags: (none) OpenGL extensions:
6 years 1 month ago - 6 years 1 month ago #181824 by TurBoss
hello,
is curious how
OpenGL extensions:
reports system using GLSL 1.30 wich is shown as compatible on the first error
can you pleas show distribution field when you click on the linuxcnc build bot repo ?
and I'm not sure if is correct to have both repositories active :? can some one confirm?
deb linuxcnc.org/
deb buildbot.linuxcnc.org
edit: maybe try
pip install --upgrade vtk
  • anfänger
  • Topic Author
  • Platinum Member
  • Platinum Member
6 years 1 month ago #181830 by anfänger
seems to have solved the problem
many thanks!
The following user(s) said Thank You: TurBoss, KCJ
Moderators: KCJ, Lcvette
Time to create page: 0.071 seconds
