- Thank you received: 6
Yes, but it requires a fair amount of hand-fiddling.I have a working Gmoccapy config using carousel component. Is it possible to use Probe Basic with the carousel component instead of the macros?
To clarify... the macros are designed to work with a geneva drive and a 'dumb' on/off motor.
If you have an ATC that doesn't follow the basic mechanical config intended by the PB devs, you'll need to do some heavy editing.
Nice!The machine is a Fadal with a 21 tool Geneva.
