Problems with vcp-template
1 year 7 months ago - 1 year 7 months ago #323438 by Nserega.90
Hello!! I apologize in advance! I am new to linuxcnc, and especially to qtvcp. I am following the instructions from here www.qtpyvcp.com/tutorials/basic_vcp/basic_vcp_01.html . After running the tutorial.sh script, I try to run the following command editvcp vcp1, but I get an error! Can you tell me what is wrong?
Warning: Spoiler!
Files in folders
Warning: Spoiler!
vcp1
Warning: Spoiler!
~./linuxcnc/configs/vcp1
Warning: Spoiler!
/home/user/qtpyvcp.log
Warning: Spoiler!
Last edit: 1 year 7 months ago by Nserega.90.
1 year 7 months ago #323451 by Lcvette
Replied by Lcvette on topic Problems with vcp-template
your best bet is to use this installation method:
github.com/Lcvette/qtpyvcp-bookworm-installer
The following user(s) said Thank You: Nserega.90
1 year 7 months ago #323491 by Nserega.90
Thanks! I'll try!
1 year 7 months ago - 1 year 7 months ago #323495 by Nserega.90
I understand this is the process of installing qtpyvcp and the Basic probe. In my case, it all works. Probably, I did not correctly identify the problem! I also correctly installed qtdesigner5 with linuxcnc widgets. But the problem is that the folder with the installed (vcp template) is not correctly configured for further editing! That is, I want to try to make my own graphical interface. I tried to create a GUI through flex gui, which was created by John, and it is very cool and quite clear. But I also want to study and try to create my GUI through qtpyvcp, but I encountered the problem that I described above!
Or you can start creating your own GUI without this step: www.qtpyvcp.com/tutorials/basic_vcp/basic_vcp_01.html
1 year 7 months ago #323523 by Lcvette
just start designing whatever you like, the template is just a starter. you can open probe basic and use it as a template also if you prefer.. its completely up to you what you create.
1 year 7 months ago #323586 by Nserega.90
Thank you! Yes, everything worked out! Your instructions were easier. I'm trying to design)))
Moderators: KCJ, Lcvette
Time to create page: 0.202 seconds
