I updated ProbyBasic to the newest dev version and I am facing two Issues. After the update, I deleted all my old folders (user tabs, subroutines, python etc...) with the new folders from the example config. I am currently trying out the ATC Rack tool Changer.
Issue1:
For this, I am trying to modify my linuxcnc.var file, manually changing the following Parameter:
"3973 10.000000
3979 1.000000
3981 -76.000000
3982 0.000000
3983 1137.000000
3984 615.680000
3985 1137.000000
3986 565.680000
3987 1097.000000
3988 615.680000"
However, when opening Linuxcnc, all the values are still 0. When modifying some values in the GUI, for example X Position for P1 to 1337, I get the error "Error: No Conditions Met, Rack ID Not Set" BUT when hitting "update Rack ATC Parameters" the Value is saved in the linuxcnc file (but all the other values above are overwritten to 0.
So, I would be fine with including all these in the GUI but the only value I can not change is the "ATC Rack ID", which seems to be write protected and, I assume, creates the error above.
EDIT: Okay, I filled now all Parameters and it seems to have created a RACK ID -> 4. And it is working now.
Issue 2:
I set up everything and can now manually clamp and release the tools. The Tool touch off is also working (on both ATC and Tool Tab). However, when clicking "Store Tool in Rack", I get the Error "Unknown m code used: M10" but M10 is in the subroutines folder.
Similar to clicking "Ref Rack Data" (what does it actually do?) I get "Unknown m code used: M13".
