Probe Basic Probing Location
1 year 3 weeks ago #336237 by maruf1777
Hi I Have Problem With Probe Basic Probing
So My CNC is:
X+ Left To Right( 0 - 330)
Y+ From Front To Back ( 0 - 200)
However When I Want To Probe Front Left Corner It Seems Like It Is Probing X Properly But Y Is Flipped
So In order to probe Front Left Corner In RL I'm forced to choose Back Left Corner in PB GUI
1 year 3 weeks ago #336238 by pommen
Replied by pommen on topic Probe Basic Probing Location
I think Probe basic is based on this:
https://linuxcnc.org/docs/html/user/images/mill-diagram_en.svg
Read more here:  linuxcnc.org/docs/html/user/user-concepts.html
The following user(s) said Thank You: maruf1777
1 year 3 weeks ago #336239 by maruf1777
It Seems Like My Y Axis Is Inverted In Wrong Direction
However I Did Set My Params in Ini
HOME = 200.0
MIN_LIMIT = 0.0
MAX_LIMIT = 200.5
HOME_OFFSET = 200.0
HOME_SEARCH_VEL = -5.0
HOME_LATCH_VEL = -5.0
After Homing It Moves In opposite direction
Is that Mean I need to Invert Motor Direction and Change Home_Search_vel to positive?
1 year 3 weeks ago #336242 by tommylight
Picture of the machine and location of home sensor ?
1 year 3 weeks ago #336248 by Lcvette
Axis direction is the direction the cutter moves through the work on a Cartesian coordinate system. For moving gantry machines it is literal but for table motion machines it can be confusing because it's inverse of what one might expect (if thinking the table is what is traveling in the + or - direction. When the table moves toward the front, the cutter is moving in the y+ direction through the work, when the table moves to the left it is the x+ direction because the cutter moves through the work in the positive direction. So setup your machine accordingly. Home should be 0's, if your switches are on the wrong side you can use the home offset setting to correct.
1 year 3 weeks ago - 1 year 3 weeks ago #336249 by maruf1777
Thanks For Info I Fixed It. Followed Directions From LinuxCNC Docs On Referncing Axis Movement And Directions Noted by pommen
Last edit: 1 year 3 weeks ago by maruf1777. Reason: Enlarged Reply
Moderators: KCJ, Lcvette
Time to create page: 0.381 seconds
