Reloading program after homing
4 years 10 months ago #229015 by bednarzmac
Why I have to reload *.ngc program every time I home axis? I use modificated QtTouchy and everytime I home single axis (I have to home X axis on every piece) I need to reload .ngc file otherwise start button is inactive. Any solutions? :)
4 years 10 months ago #229017 by cmorley
Mostly because it's not expected that you would need to home every time you need to run the program. Should probably fix that.
I'll look into the button logic when I'm free to see if I can make that better.
What did you modify in qttouchy?
4 years 10 months ago - 4 years 10 months ago #229018 by bednarzmac
I changed some buttons, deleted all jogging stuff (i have jogging on hardware side), deleted/hanged some tabs and changed some visual stuff.
Last edit: 4 years 10 months ago by bednarzmac.
4 years 10 months ago #229026 by cmorley
Ahh looks good.
Are you using linuxcnc 2.8 or 2.9?
4 years 10 months ago #229037 by cmorley
When you say start button, you mean an on screen (actionbutton) start button?
Is the button greyed out (disabled) or just doesn't start the program running.
4 years 10 months ago #229061 by bednarzmac
Hi, yes I mean actionbutton "start". It is shaded and inactive.
I use 2.9.0 + Mesa 7i97 (ethernet+analog)
Time to create page: 0.064 seconds
