Sorry for running straight to the forum, but I really need to get this machine back up...
I've switched to QTDragon_HD from Axis. I'm running 2.9.2 from the Deb ISO. Everything appears to be running. I've touched off a tool and am ready to run. I hit cycle start on my g-code (from Fusion 360) and the program runs a few lines, does a move and then stops on the line with "T4 M6". So fine, manual tool change but no pop up to say go. Just sits there.
- I have the 3 manual tool change lines in qtdragon_hd_postgui.hal per the doc's. (and commented out in my original .hal)
- qtdragon_hd_postgui.hal is being sourced from postgui_call_list.hal which I can see happening while running fm command line
- I have commented out the "unlink" commands for the tool change lines (tried leaving them in too - no difference)
I don't see a loadusr -W hal_manualtoolchange component being loaded and I presume that QTDHD is handling this in python (since clearly the machine is waiting).
What am I missing?
