QTDragon and DTG readout
1 year 5 months ago - 1 year 5 months ago #328592 by Roguish
well, needed to do some machining... Updated to the latest Master branch in buildbot2 a couple days ago.
when running, I really like to see both the current position and distance to go (DTG) displayed simultaneously.
the display doesn't do that, at least not stock out of the box.
can it?  axis sure does.
How can it be made to?   hopefully not customizing anything....I've worked hard getting away from that...
Also, what is MPG Scroll do????
see the picture....
Last edit: 1 year 5 months ago by Roguish.
1 year 5 months ago #328594 by cmorley
Replied by cmorley on topic QTDragon and DTG readout
No, not without a customization.
1 year 5 months ago #328595 by Roguish
Replied by Roguish on topic QTDragon and DTG readout
Chris,, thanks.
but what is the MPG SCROLL thing ??
1 year 5 months ago #328607 by cmorley
As a quick solution pull again:
The following user(s) said Thank You: Roguish
1 year 5 months ago #328608 by cmorley
overlay DRO can be selected from the options button
1 year 5 months ago #328610 by cmorley
You can use an MPG to scroll the gcode graphics and gcode editor and other widgets.
Set the button, touch the widget, the border should change, then it will scroll
You can check it out with the QtDragon_lathe sim
Time to create page: 0.231 seconds
