I corrected the program prefix, to be one and have the "~" at the start. Ran again I am getting the following from the terminal. The path is valid as well. The following is from the terminal
home/cnc/linuxcnc/configs/New_TAIG_dragon/New_TAIG_dragon.ini:92: executing 'import sys
sys.path.append("/home/cnc/linuxcnc/nc_files/examples/remap_lib/python-stdglue/python")'
PythonPlugin: Python '3.13.5 (main, Jun 25 2025, 18:55:22) [GCC 14.2.0]'
is_callable(__init__) = FALSE
[QTvcp.QTVCP.QT_ISTAT][WARNING] Path not valid in INI File [DISPLAY] PROGRAM_PREFIX section (qt_istat.py:96)
[QTvcp.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MAX_LINEAR_VELOCITY Entry in DISPLAY, Using: 5 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MAX_SPINDLE_POWER Entry in DISPLAY, Using: 1500 (qt_istat.py:532)
is_callable(oword.on_abort) = FALSE
task: main loop took 0.119162 seconds
is_callable(oword.qt_auto_probe_tool) = FALSE
I compared to the sim .ini file and found that the "~" was not part of the program_prefix. Running it again without the "~", cleared the error
Still does not work but this was noticable
Running the sim actually in debug shows the same thing..
/home/cnc/linuxcnc/configs/sim.qtdragon.qtdragon_tool_probe/qtdragon_auto_tool_probe.ini:120: executing 'import sys
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
tool_result(id=2, xoffset=0.0, yoffset=0.0, zoffset=0.1, aoffset=0.0, boffset=0.0, coffset=0.0, uoffset=0.0, voffset=0.0, woffset=0.0, diameter=0.0625, frontangle=0.0, backangle=0.0, orientation=0)
