Advice on Designing a GUI for a Custom C-Based EtherCAT CNC Controller on Linux
1 week 5 days ago #350356 by ajanfahri
Hello everyone,I'm developing a custom CNC controller on Ubuntu Linux with real-time capabilities. The core control system is being written in C, and I'm working on integrating EtherCAT for servo drive communication.I'm now considering the best approach for designing the user interface (HMI).My main questions are:
  • Should I develop the entire application, including the GUI, in C/C++ using a native Linux GUI framework?
  • Would it be better to build a modern web-based interface using React, with a separate backend communicating with the C control core?
  • What architecture would you recommend for a CNC controller that requires reliable real-time motion control, low latency, and a responsive user interface?
  • Are there any existing LinuxCNC components or libraries worth considering for this purpose?
My priority is to keep the real-time control layer independent of the GUI, while making the interface modern, maintainable, and easy to extend.I'd appreciate hearing about your experiences and recommendations.Thank you!
The following user(s) said Thank You: Shu
1 week 4 days ago #350371 by tommylight
There are plenty of GUI's included with LinuxCNC that you can test and run without a machine, even without installing anything, just download the ISO, burn to a USB, boot the PC from it and test as much as you like.
There are also:
-QtPyVCP, a separate project for LinuxCNC for small and big industrial mills with toolchangers and everything, and a lathe version being actively developed
-FlexGUI, a GUI editor/maker for LinuxCNC, very easy to use and very capable as far as i can see/read here on the forum, depending on what you need you can have a working GUI very fast (i would guess under an hour).
There are many other versions of web based or even LabView (i am not sure about the name, but expensive proprietary software that can be made to work with LinuxCNC), etc.
My advice, start with FlexGUI:
forum.linuxcnc.org/flex-gui/57726-flex-gui
1 week 3 days ago #350395 by ajanfahri
Thanks for your suggestions! I'll look into your recommendations.(FlexGUI and QtPyVCP.)
However, I'm developing my own CNC controller from scratch rather than using LinuxCNC. The real-time control core is written in C, and I'm integrating EtherCAT for servo communication.
I'm mainly trying to decide on the best HMI architecture for my own system: a native C/C++ GUI or a modern React-based web interface communicating with the C control core through a separate backend.
I'd be interested in your thoughts on this architecture, particularly regarding reliability, real-time performance, and communication between the HMI and the control core.
1 week 3 days ago #350398 by NWE
Where can we view the source code?
The following user(s) said Thank You: ajanfahri
1 week 3 days ago #350399 by tommylight
Trajectory planner is not an easy task, so i would stick with LinuxCNC for that (as do most companies using it) and do your HMI/GUI for it.
C/C++ is fine, React i have no clue (is that a version of Java script?), but whatever you end up using, make sure that if it crashes, it does not take the trajectory planner and real time stuff with it.
For me reliability is paramount, so i stick with Axis GUI mostly, i distinctly recall some 10 years back messing with Linux deleting stuff while the machine was working, i broke something, screen went black, keyboard was not doing anything, but the machine went on to finish the part over two hours after blacking out!
Having industrial machines With LinuxCNC running 24/7 for nearly 15 years without ever having any issues is something big companies can not do, of course as most of those still use windoze! :)
1 week 3 days ago #350402 by ajanfahri
The project is still under development. The CNC software I have worked with is proprietary, so I cannot share its source code.
My current project is a separate development using Linux, Xenomai for real-time capabilities, and EtherCAT for motion control. I'm still working on the architecture and exploring the HMI approach.
Time to create page: 0.093 seconds
