4th axis tangent to path XY
26 May 2012 21:04 #20430
by billykid
Replied by billykid on topic Re:4th axis tangent to path XY
hi all
I tried tangentkins. and seems to work, only that I have the button touch off inactive (gray)
you know it can be?
thanks
Mauro
you know it can be?
thanks
Mauro
26 May 2012 23:28 #20432
Replied by andypugh on topic Re:4th axis tangent to path XY
billykid wrote:
Sorry, no, I have no idea. I doubt it is related to the kinematics, I assume there is something about the machine state in Axis that means that touch-off isn't likely.
Do you need to switch to World Mode? (xyz positions, not 123 joints). There is a menu option, or use $
hi all
you know it can be?
27 May 2012 00:41 #20437
by BigJohnT
Replied by BigJohnT on topic Re:4th axis tangent to path XY
In Axis you can only touch off when E-Stop is out, Power is On and you are in World Mode. F1, F2, $ is the shortcut keys.
27 May 2012 16:43 #20450
by billykid
Many thanks Andy, John ! touch off work properly but axes in world mode are noisy, I think perhaps excessive gain.
in mode 0 1 2 3 the movement is fluid.
I will try the next version of tangentkins so that it can be enabled only when needed.
mauro
mauro
23 Jul 2013 11:23 #36928
by nkp
Replied by nkp on topic 4th axis tangent to path XY
tell me please , how to activate the tangentkins and in the mode "manual"?
To make it work in all modes without exception...
23 Jul 2013 16:01 #36932
If I was doing it now, I think that I would use the axis.0.joint-vel-cmd and axis.1.joint-vel-cmd pins to calculate the tangent direction, and probably use a custom HAL component to drive the rotary axis.
This custom HAL component might require a link to the feed over-ride pin to slow the motion on a reversal.
Replied by andypugh on topic 4th axis tangent to path XY
Unfortunately Tangentkins is something of an experiment that nearly worked, rather than a good solution to the issue.tell me please , how to activate the tangentkins and in the mode "manual"?
20 Oct 2015 19:06 #63999
by mgenton85
Replied by mgenton85 on topic 4th axis tangent to path XY
Has there been any further dev on tangential path follow or does anyone know of a cam program that will give the c axis output with xyza ?
20 Oct 2015 20:57 #64002
From a quick Google it seems that Gcodetools (a plug-in for Inkscape) can do this.
An alternative would be an input filter for LinuxCNC. This would take normal XY G-code and add additional C-axis moves.
20 Oct 2015 22:08 #64005
by mgenton85
yeah that makes no sense to me i tried to use the tangentkins with 2.6.4 but all that happens is joint 3 following error and i dont really understand the language yet
if tangentkins worked that would be ideal can you provide a helpful link so i can decode and learn your program? because i really need to have this capability and i refuse to go back to mach mach 60 ipm with steppers linux 200 ipm same setup except for encoders yeah not going backwards
20 Oct 2015 22:21 #64006
Can you re-phrase the question? I am not sure what you mean.
Time to create page: 0.149 seconds
