CPLD for GPIO
06 Aug 2014 03:42 #49541
by vre
CPLD for GPIO was created by vre
Is possible to connect a cheap cpld like these
www.ebay.com/itm/MAX-II-EPM240-CPLD-Mini...ard-5V-/181441010315
www.ebay.com/itm/1PCS-New-MAXII-EPM570-C...d-JTAG-/271037690097
with serial interface to linuxcnc ?
Α real time serial link with a mesa card ?
These boards are very cheap and have a lot of i/o
11 Aug 2014 23:00 - 04 Apr 2016 14:53 #49704
by numbskull
Replied by numbskull on topic CPLD for GPIO
question misunderstood - original reply withdrawn
Last edit: 04 Apr 2016 14:53 by numbskull.
11 Aug 2014 23:38 - 04 Apr 2016 14:54 #49707
by numbskull
Last edit: 04 Apr 2016 14:54 by numbskull.
12 Aug 2014 00:29 - 12 Aug 2014 00:30 #49711
Replied by PCW on topic CPLD for GPIO
You probably could use one of those as I/O expansion
for a Linuxcnc/Machinekit host that has a SPI port
(BeagleBone, CubieBoard, RasPI etc) or a mesa card with SPI firmware but you would need to do driver work (or component work for Mesa)
to get SPI access from HAL
Not as cheap but if you want TTL level GPIO expansion from a Mesa system,
a 7I90 running SSREMOTE firmware works (72 five volt tolerant real time I/O bits, long distance capable RS-422 link)
Last edit: 12 Aug 2014 00:30 by PCW.
13 Aug 2014 22:28 - 04 Apr 2016 14:54 #49821
by numbskull
19 Aug 2014 06:02 #50027
by vre
Replied by vre on topic CPLD for GPIO
I want to use a core for UART from web and mesa_uart component.
Anyway this is for experimenting not for a working machine. For a real machine i will get something that works like 7i90.
7i90HD is very nice and cheap but out of stock.. I hope until my next next order from mesa to be stocked again.Not as cheap but if you want TTL level GPIO expansion from a Mesa system,
19 Aug 2014 06:44 #50029
The 7I90HD should be available in a couple of days
03 Aug 2018 04:45 #115484
by tivoi
Replied by tivoi on topic CPLD for GPIO
HI PCW, how to setting baurate for 7i90 run ssremote
03 Aug 2018 12:59 #115510
As a standard SS remote device, the 7I90 runs at 2.5 MBaud. This is not changeable with the current firmware.
03 Aug 2018 13:21 #115513
by tivoi
Thanks PCW, let me try
Time to create page: 0.546 seconds
