5 Axis ParPort Stepper Setup with RTCP
25 Sep 2015 20:47 #62981 by andypugh
All I can suggest is checking values in Halmeter and/or Halscope to make sure that the numbers going in to the kinematics are as-expected, and to make sure that your kinematics calculations are really doing what you want.
Do the calculations include the tool length offset? Does the Vismach model accurately represent the tool length? Vismach just plots the position of the end of the tool shape in its own private space, it knowns nothing at all about the kinematics or the real machine.
Your kinematics was meant to ignore C. Does it?
The following user(s) said Thank You: marq_torque
25 Sep 2015 20:58 - 25 Sep 2015 21:00 #62984 by marq_torque
This is 5Axiskin i am testing now. need some hint where to focus??
Yes andypugh i want to ignore C axis.
as i have solved trigonometry
For X = [X DRO + {(Sin( B )) * (Pivot length + Tool offset)}]
For Z = [Z DRO + {(Pivot Length + Tool Offset) -(Cos( B )*(Pivot Length+ Tool Offset))}]
but i am noob in C ...so not able to figure out how to include this calculation :unsure:
* Description: 5axiskins.c
* Trivial kinematics for 3 axis Cartesian machine
* Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2007 Chris Radek
* Last change:
#include "kinematics.h" /* these decls */
#include "posemath.h"
#include "hal.h"
#include "rtapi_math.h"
#define d2r(d) ((d)*PM_PI/180.0)
#define r2d(r) ((r)*180.0/PM_PI)
struct haldata {
hal_float_t *tool_length;
hal_float_t *pivot_length;
} *haldata;
static PmCartesian s2r(double r, double t, double p) {
PmCartesian c;
t = d2r(t), p = d2r(p);
c.x = r * sin(p) * cos(t);
c.y = r * sin(p) * sin(t);
c.z = r * cos(p);
return c;
int kinematicsForward(const double *joints,
EmcPose * pos,
const KINEMATICS_FORWARD_FLAGS * fflags,
KINEMATICS_INVERSE_FLAGS * iflags)
PmCartesian r = s2r(*(haldata->pivot_length) + joints[8], 0, 180.0 - joints[4]);
pos->tran.x = joints[0] + r.x;
pos->tran.y = joints[1] + r.y;
pos->tran.z = joints[2] + *(haldata->pivot_length) + r.z;
pos->a = joints[3];
pos->b = joints[4];
pos->c = joints[5];
pos->u = joints[6];
pos->v = joints[7];
pos->w = joints[8];
return 0;
int kinematicsInverse(const EmcPose * pos,
double *joints,
const KINEMATICS_INVERSE_FLAGS * iflags,
KINEMATICS_FORWARD_FLAGS * fflags)
PmCartesian r = s2r(*(haldata->pivot_length) + pos->w, 0, 180.0 - pos->b);
joints[0] = pos->tran.x - r.x;
joints[1] = pos->tran.y - r.y;
joints[2] = pos->tran.z - *(haldata->pivot_length) - r.z;
joints[3] = pos->a;
joints[4] = pos->b;
joints[5] = pos->c;
joints[6] = pos->u;
joints[7] = pos->v;
joints[8] = pos->w;
return 0;
/* implemented for these kinematics as giving joints preference */
int kinematicsHome(EmcPose * world,
double *joint,
*fflags = 0;
*iflags = 0;
return kinematicsForward(joint, world, fflags, iflags);
KINEMATICS_TYPE kinematicsType()
return KINEMATICS_BOTH;
#include "rtapi.h" /* RTAPI realtime OS API */
#include "rtapi_app.h" /* RTAPI realtime module decls */
#include "hal.h"
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsForward);
EXPORT_SYMBOL(kinematicsInverse);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
int result;
comp_id = hal_init("5axiskins");
if(comp_id < 0) return comp_id;
haldata = hal_malloc(sizeof(struct haldata));
result = hal_pin_float_new("5axiskins.tooloffset.z", HAL_IN, &(haldata->tool_length), comp_id);
if(result < 0) goto error;
result = hal_pin_float_new("5axiskins.pivot-length", HAL_IO, &(haldata->pivot_length), comp_id);
*(haldata->pivot_length) = 250.0;
hal_ready(comp_id);
return 0;
error:
hal_exit(comp_id);
return result;
void rtapi_app_exit(void) { hal_exit(comp_id); }
Last edit: 25 Sep 2015 21:00 by marq_torque.
25 Sep 2015 22:45 #62991 by andypugh
It is fairly clear that tool_length isn't being used in the calculations. That solves one puzzle.
As for the rest, you may not need the pmcartesian, and d2r and r2d are degrees to radian conversions because C trigonometry functions use radians.
So, if it's easier for you just put the equations in axis/joint caclulations line.
The functions and constants you can think of using are here:
www.cs.cf.ac.uk/Dave/C/node17.html
You will just have to become a little less noob about C to figure out the syntax. You can only use () brackets and the line has to end with ;
You need to use *(haldata->pivot_length) to get the pivot length value from the HAL pin and *(haldata->tool_length) to get thte tool length.
Then is is just a matter of reading the error reports and acting on them until it compiles and works.
26 Sep 2015 01:51 #62995 by marq_torque
thanks for quick and prompt reply @andypugh,
i am in lots of question on your answers ... i m not understanding what you are saying to change ... can you please explain me ?? :)
26 Sep 2015 02:01 #62996 by andypugh
Change the calculations to be the calculations you want to do.
You will need to learn at least the rudiments of C. However that code uses #defines and helper functions, and that is probably making it harder for you to understand.
26 Sep 2015 02:06 - 26 Sep 2015 02:08 #62997 by marq_torque
can you guide me where to include with what lines exactly ??
so do i need to remove those lines ???
okay thats what i want to do ...i want to remove all clutter expect the equations for x and z ... but how ? :ohmy:
Last edit: 26 Sep 2015 02:08 by marq_torque.
26 Sep 2015 02:15 #62998 by andypugh
I think it is probably easier to read the code if you carry on using the functions.
Take out all the lines that do the wrong things, and replace them with lines that do the right things.
First read enough stuff to be able to at least understand C syntax, and what it is all doing.
I am running out of motivation here, it's your machine, you need to put the work in.
26 Sep 2015 02:24 #62999 by marq_torque
do you mean i need to add new line ?? after ..
i guess ??
26 Sep 2015 02:29 #63001 by andypugh
Learn some C. I really don't have the time to teach you.
26 Sep 2015 02:31 #63002 by marq_torque
Yes yes trying to :) :)
btw thanks big time for taking this much hassle :)
Time to create page: 0.096 seconds
