How to build ATC Carousel in linuxcnc ?
- Thank you received: 5934
01 Jun 2020 11:31 #169651
Replied by tommylight on topic How to build ATC Carousel in linuxcnc ?
It could be done just using gcode O subs, or using the carousel component of LinuxCNC.
It can also be done with M6 remap, but i would not use remap.
Does the tool changer have any position sensors? Having an index and another sensor for counting the positions would make it very nice for the carousel comp.
01 Jun 2020 11:45 #169653
The "carousel" HAL component already does what you need for this application:
So 2 and 14 would both position the carousel in the same place. Then the tool0change logic needs to decide what axis moves are needed, ie left or right of the tool changer.
Replied by andypugh on topic How to build ATC Carousel in linuxcnc ?
It's vertical 2 by X Tool Changer. So, for example 24 tools in total: tools 1 - 12 on the left side and tools 13 - 24 on the right.
Still trying to figure out what the best approach would be accomplish this type of tool changer.
pin in signed pocket-number """The pocket to move to when the .enable pin goes high. If the value
passed is gigher than the number of pockests specified in the "pockets" modparam then modulo arithmetic
is used. This is intended to allow the use of multiple tools in the same holder, as is sometimes
useful with lathes.""";
01 Jun 2020 11:47 #169655
by 0x2102
Replied by 0x2102 on topic How to build ATC Carousel in linuxcnc ?
I am still thinking about how to index/position it. Right now I would say 5 proximity sensors (1 index / 4 binary or gray code) to identify position of the carousel.
01 Jun 2020 11:53 #169656
That's definitely the way that I would recommend. There are other possibilities but I think Gray code + strobe is definitely the most dependable. Add another sensor for parity, if you want to be super-confident. (Then if any single sensor fails an error will be triggered)
28 Jun 2020 01:37 #172938
by rogerxue
Replied by rogerxue on topic How to build ATC Carousel in linuxcnc ?
Hi Andy, Do you have a concrete example of how to use the carousel component? I checked VMC_toolchange, but it's still not very clear to me how to use it. For example, I see the signal car-enable gets created, but nowhere does it get used, I assume it need to connect to some other pin to actually use it?
also if I have a "home" switch on my carousel, will that get connected to the carousel.N.ready pin?
still try to understand how to use it
thanks for your help
28 Jun 2020 02:14 #172941
VMC_toolchange is as concrete as it gets.
(I have configured a couple of machines to use it, but none were my own and I don't have the configs)
What does the "home" pin on your carousel indicate?
In many cases it will connect to sense-0 and be the pocket-1 indicator.
28 Jun 2020 02:19 #172942
Where are you looking?
That is linking the signal to the carousel enable, and to a G-code digital output.
net car-enable motion.digital-out-00 carousel.0.enable
28 Jun 2020 03:56 #172945
by rogerxue
my bad, I was looking at a older verison.
So if I decide to use stepgen to drive stepper, then
carousel.N.fwd-dc should be net to stepgen.<chan>.velocity-cmd?
again thanks for the help
28 Jun 2020 10:28 #172967
Yes, even if you are using LinuxCNC 2.7 you probably want to install the 2.8 version of "carousel".
Close, except that fwd-dc is an input that tells the component how fast to move in fwd. the actual output to the stepgen is the pin carousel.0.motor-vel
You would need to setp the dc pins to suitable fixed speeds.
net motor-speed carousel.0.motor-vel stepgen.11.velocity-cmd
setp carousel.0.fwd-dc 100
setp carousel.0.rev-dc 100
setp carousel.0.hold-dc 0
Time to create page: 0.152 seconds
