Punch Press Gcode
08 Jun 2017 08:56 #94281
by AElmasry
It's works fine once I changed the file name in my config to g11 instead of G11.
Thanks andypugh
It's taken me a while to figure out how to do it till you helped me.
Replied by AElmasry on topic Punch Press Gcode
I added your code before my gcode program and it worked very well.
Is this the right way to remap g11, put it's code inside every ngc file?
No, you should be able to put g11.ngc in the config directory, and then g11 is a new G-code.
Thanks andypugh
08 Jun 2017 09:18 #94283
Replied by andypugh on topic Punch Press Gcode
As a general rule everything in g-code is converted to lower-case before being parsed by the interpreter, so it is generally best to use lower case for the names of subroutines and in external references.
Personally I prefer capitals in the actual G-code, and that it very much OK.
08 Jun 2017 11:19 #94287
by AElmasry
The machine was on default G64, I tried G61 and re-tuned the motors but still the same problem exists.
I Tried also G61.1 with the same results.
The machine also set to actual position.
Is there anything else I can do?
Don't know if this is the answer, but is the machine set for G61.1 mode or the default G64 mode (or G61)?
- Thank you received: 1369
08 Jun 2017 11:33 #94288
Replied by Todd Zuercher on topic Punch Press Gcode
If it is set to actual position, you are seeing that the machine is within the minimum following error, so it is "in position". If you change the DRO to Commanded Position I think you might not see the problem. (but not correct it)
If you tighten up the minimum following error, so that it is less than what rounding the error up would be, will not let it show up on your DRO, and should fix it. (I think) Assuming that your servos can achieve that kind of resolution.
Time to create page: 0.317 seconds
