5 axis kinematics setup
14 Nov 2017 23:28 #101808
by agsarg
Replied by agsarg on topic 5 axis kinematics setup
Ok just tested that and the module seems to be the problem as i can load any compiled modules from default linuxcnc but when i try to load it there s a msg error and i have to reboot to load anotherone. How do you recommend to save and pass the file to build? i think that might be the problem ive been saving it as a c source code with codeblocks from a windows pc and passing the source file to my linux pc. i can t think of other possibilities.
Just to be clear with your reply, when you call { loadrt etckins } do you call an argument on that line if the module is connected by pins from the hal? thanks
15 Nov 2017 00:47 - 15 Nov 2017 00:47 #101812
Replied by andypugh on topic 5 axis kinematics setup
Many kinematics modules do not create any HAL pins.
All kinematics modules export a set functions with the same names, and that is how the motion module accesses them.
That's what this bit of code does:
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsInverse);
EXPORT_SYMBOL(kinematicsForward);
Last edit: 15 Nov 2017 00:47 by andypugh.
18 Nov 2017 15:39 #101977
by agsarg
Hello, i ve been a little busy these days so i tried rebooting the pc to clean up the memory and re running a standard lcnc config. then i re installed the module and declaring it on the config files, and it looks like it works. So now i am trying to run the vismach simulation to visualize the difference in motion. Thanks for your help. I still have a little question. If my kinematics module creates hal pins do i have to declare them in the ini file?
18 Nov 2017 16:01 #101978
No, but you might want to set them to values of link them to nets in the HAL file.
The following user(s) said Thank You: agsarg
25 Jan 2018 16:26 - 27 Jan 2018 16:04 #105007
by 3D-Master
Replied by 3D-Master on topic 5 axis kinematics setup
any news?
Edit: just noticed i replied to the wrong post lol
Last edit: 27 Jan 2018 16:04 by 3D-Master.
Time to create page: 0.181 seconds
