Touch panel question
07 Jun 2018 11:07 #111857
by tecno
Replied by tecno on topic Touch panel question
Section "InputClass"
Identifier "calibration"
MatchProduct "eGalax"
Option "calibration" "70000 1000 1000 70000"
EndSection
Just playing around with numbers, above results in cursor towards center in each corner. So it looks like numbers stick, will test some more. BRB
EndSection
07 Jun 2018 11:14 - 07 Jun 2018 11:15 #111858
by tecno
Sorry, false alarm! Still no change = numbers will not stick!
Last edit: 07 Jun 2018 11:15 by tecno.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
07 Jun 2018 11:46 #111861
by InMyDarkestHour
Where and what name are you saving this file ?
Replied by InMyDarkestHour on topic Touch panel question
EndSection
07 Jun 2018 11:47 #111862
by tecno
/etc/X11/xorg.conf
- InMyDarkestHour
- User is blocked
07 Jun 2018 12:25 #111865
by InMyDarkestHour
Have tried doing the following
Then creating your conf file in /etc/X11/xorg.conf.d called 10-calibrate.conf
Which seems to be a recommended method according to the man page for xorg.conf
Or editing /usr/share/X11/xorg.conf.d/10-evdev.conf as per this page www.thefanclub.co.za/how-to/how-ubuntu-1...chscreen-calibration
Would still be interested in the output of
sudo mkdir /etc/X11/xorg.conf.d
ls /dev/input/*
07 Jun 2018 12:34 #111866
by tecno
bengt@combimill:~$ ls /dev/input/*
/dev/input/event0 /dev/input/event3 /dev/input/mice
/dev/input/event1 /dev/input/event4 /dev/input/mouse0
/dev/input/event2 /dev/input/event5 /dev/input/mouse1
/dev/input/by-id:
usb-1ea7_2.4G_Keyboard-event-kbd
usb-1ea7_2.4G_Keyboard-if01-event-mouse
usb-1ea7_2.4G_Keyboard-if01-mouse
usb-eGalax_Inc._USB_TouchController-event-if00
/dev/input/by-path:
pci-0000:00:1d.0-usb-0:1:1.0-event-kbd pci-0000:00:1d.1-usb-0:1:1.0-event
pci-0000:00:1d.0-usb-0:1:1.1-event-mouse platform-pcspkr-event-spkr
pci-0000:00:1d.0-usb-0:1:1.1-mouse
bengt@combimill:~$
/dev/input/by-id:
/dev/input/by-path:
bengt@combimill:~$
07 Jun 2018 13:06 - 07 Jun 2018 13:07 #111871
by tecno
Now we are getting somewhere, what we now know is that several conf files is not good as they seem to override each other . Deleted after some tests /etc/X11/xorg.conf and now the 10-evdev.conf seems to be working but I have to tweak the numbers.
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
option "calibration" "355 2011 299 1904"
EndSection
Appears to be a bit non linear, if i point right side and move to left cursor moves faster away from my touchpoint.
Will have to play around a bit to find out acceptable numbers.
Cheers
Bengt
Would still be interested in the output ofls /dev/input/*
Driver "evdev"
EndSection
Cheers
Bengt
Last edit: 07 Jun 2018 13:07 by tecno.
- InMyDarkestHour
- User is blocked
07 Jun 2018 13:20 - 07 Jun 2018 13:23 #111873
by InMyDarkestHour
Well at least something is happening.
Will give you some of the options available, I don't know which ones will help, but this one looks interesting
Option "GrabDevice" "boolean"
Force a grab on the event device. Doing so will ensure that no other driver can initialise the same device and it will also stop the device from sending events to /dev/kbd or /dev/input/mice. Events from this device will not be sent to virtual devices (e.g. rfkill or the Macintosh mouse button emulation). Default: disabled.
man evdev
Last edit: 07 Jun 2018 13:23 by InMyDarkestHour.
07 Jun 2018 13:25 #111875
by tecno
YEYYYYYYYYYYYY
Driver "evdev"
option "calibration" "54 1949 118 1951"
EndSection
My lucky numbers = the touch on my milling machine is now working = spot on
THANK YOU GUYS FOR HELPING OUT WITH THIS = MUCH APPRECIATED
Driver "evdev"
EndSection
- InMyDarkestHour
- User is blocked
07 Jun 2018 13:29 #111877
by InMyDarkestHour
Should make my life a little easier when I get around to it.
After all this did you end up having to swap any wires or not ?
CONGRATULATIONS
Time to create page: 0.127 seconds
