Touch panel question
- InMyDarkestHour
- User is blocked
- Thank you received: 111
04 Jun 2018 21:28 #111625
by InMyDarkestHour
Replied by InMyDarkestHour on topic Touch panel question
I found this
karuppuswamy.com/wordpress/2013/01/17/ho...it-working-in-linux/
Link to manufacturers driver
www.eeti.com/drivers_Linux.html
Maybe this might be of some help
- Mike_Eitel
- Thank you received: 185
05 Jun 2018 06:26 #111647
by Mike_Eitel
Replied by Mike_Eitel on topic Touch panel question
Hi Tino
Things changed for me after:
I deinstalled libinput and installed evdev system. And xinput-calibrator calibrator.
All as root.
Mike
All as root.
Mike
05 Jun 2018 08:38 #111655
by tecno
Replied by tecno on topic Touch panel question
Tried to install EETI drivers.
Get this message from setup.sh
So obviously the USB adapter is not HID compliant = It seems Eeti is not the way to go here
echo "(W) Found a non-HID compliant touch controller."
echo "(W) This driver doesn't support non-HID touch controller."
echo "(W) Please update touch driver."
RemoveDriver
- InMyDarkestHour
- User is blocked
05 Jun 2018 12:21 #111670
by InMyDarkestHour
What does lsusb show for the touchscreen.
And sudo dmesg | grep touch
In the kernel config in the /boot directory (It should be named config-[name of current kernel]) can you find a line such as:
CONFIG_TOUCHSCREEN_USB_EGALAX=y
or
CONFIG_TOUCHSCREEN_USB_EGALAX=m
or
# CONFIG_TOUCHSCREEN_USB_EGALAX is not set
These lines should be the same, but the main part is EGALAX is what we are looking for.
or
or
05 Jun 2018 12:29 #111671
by tecno
Will check later today, however Egalax shows up in calibrator.
forum.linuxcnc.org/10-advanced-configura...tion?start=20#111601
- InMyDarkestHour
- User is blocked
05 Jun 2018 12:47 #111676
by InMyDarkestHour
The page I linked to:
Mentions something about a patched xf86-input-evtouch driver and
building the calibrator tool as per link below (I don't know if you have built this or not).
www.freedesktop.org/wiki/Software/xinput_calibrator/
I'm kind of winging it and trying no to point you in the wrong direction as I haven't purchased my touchscreen overlay yet, but these would be the steps I'd be investigating. So I apologise for any troubles or wrong directions.
05 Jun 2018 12:58 #111677
by tecno
Installed xinput_calibrator deb package from www.freedesktop.org/wiki/Software/xinput_calibrator/
The funny thing it works (loose on thew table) OK with both touch-foils on my laptop that is after calibration touch and cursor is there where it should be. But this is not the PC I will run these on.
I have just received a download link from manufacturer with drivers and will try this hopefully later today.
Just now I am not feeling so well
So my friend, there is nothing to apologise as we all try to help as good as we can.
The following user(s) said Thank You: Todd Zuercher
06 Jun 2018 14:42 #111759
by tecno
bengt@combimill:~$ sudo dmesg | grep touch
[sudo] lösenord för bengt:
[ 13.284724] usbcore: registered new interface driver usbtouchscreen
bengt@combimill:~$ lsusb
Bus 001 Device 004: ID 1a19:1628
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 0eef:0001 D-WAV Scientific Co., Ltd eGalax TouchScreen
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 1ea7:0066
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
bengt@combimill:~$
Unfortunately I get nowhere with the new drivers, looks like I have no SU as I get error with no access to folders
bengt@combimill:~$
06 Jun 2018 15:47 #111763
by tecno
Above install instructions
Something is wrong as the script will no all the way - looks like xmkmf is missing
This is stressful not to get anything to work as regards touch.
I can fix the download link from the chinese factory if needed.
Any hints on what to try next?
bengt@combimill:~/Hämtningar/touchkit/include$ sudo su
root@combimill:/home/bengt/Hämtningar/touchkit/include# make new
rm -f configSTR.h configSTR.mak configINT.h configINT.mak touch.tcl
tclsh ../utility/tcl2h.tcl configSTR.tcl > configSTR.h
tclsh ../utility/tcl2mak.tcl configSTR.tcl > configSTR.mak
tclsh ../utility/tcl2h.tcl configINT.tcl > configINT.h
tclsh ../utility/tcl2mak.tcl configINT.tcl > configINT.mak
tclsh ../utility/ini2tcl.tcl touch.ini > touch.tcl
bengt@combimill:~/Hämtningar/touchkit$ sudo su
root@combimill:/home/bengt/Hämtningar/touchkit# make all
for n in include driver utility xf86drv diag usb; do \
make -C $n || exit 1; \
done
make[1]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/include”
make[1]: Inget behöver göras för ”all”.
make[1]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/include”
make[1]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/driver”
for t in tpaneld; do \
if [ -f $t ]; then \
cp -f $t bin; \
fi; \
done
make[1]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/driver”
make[1]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/utility”
for t in PanelInfo WriteConf; do \
cp -f $t bin; \
fi; \
done
make[1]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/utility”
make[1]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/xf86drv”
make -s proceed
make[2]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/xf86drv”
## XF86 src does NOT exist; use precompiled binary instead ##
make[2]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/xf86drv”
if [ 11 -gt 400 ]; then \
if [ -f touchkit_drv.o ]; then \
cp -f touchkit_drv.o bin; \
fi; \
else \
if [ -f xf86TouchKit.so ]; then \
cp -f xf86TouchKit.so bin; \
fi; \
fi
make[1]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/xf86drv”
make[1]: Går till katalogen ”/home/bengt/Hämtningar/touchkit/diag”
xmkmf
make[1]: xmkmf: Kommandot hittades inte
makefile:39: receptet för målet ”Makefile” misslyckades
make[1]: *** [Makefile] Fel 127
make[1]: Lämnar katalogen ”/home/bengt/Hämtningar/touchkit/diag”
Makefile:55: receptet för målet ”all” misslyckades
make: *** [all] Fel 1
06 Jun 2018 16:04 - 06 Jun 2018 16:09 #111765
by tecno
Above the latest drivers from China
Here a link to the whole package
drive.google.com/open?id=1Lg24_9ivjsNA1yf3rBZW6PNVzKv4VOg7
Last edit: 06 Jun 2018 16:09 by tecno. Reason: added text
Time to create page: 0.130 seconds
