Unlimited rotary axis
16 Jul 2018 18:05 #114324
by jsskangas
Replied by jsskangas on topic Unlimited rotary axis
Well it does not work.
I tried it again 1 minute ago.
If it works as you mentioned, this is what I'm looking for.
I need it to operate as it now does and end up where ever after 5-axis operation.
But when i call c0. it would find closest way to 0 position.
"You don't want 360 and 720 to be exactly the same"
Some of our clients machines work this way, I don't see any issues with it.
I just needed to do post that can handle it.
Machine was Mikron HPM 800 , with iTNC530 control.
There are several different ways to handle rotary axis:
Okuma uses M codes for rotation direction and axis values are 0-360.
Some uses magnitude to control rotation direction, some uses sign (+-) for same thing.
16 Jul 2018 18:53 #114328
by jsskangas
Could it be cause I'm running 2.8 pre.
where joint and axis are separated and this functionality was not included?
16 Jul 2018 18:55 - 16 Jul 2018 18:55 #114329
Which version of LinuxCNC are you using, and where dos you add the WRAPPED_ROTARY line?
I just set up a simulator with A-axis as WRAPPED_ROTARY and B-axis as normal.
G91 G0 A810 B810 => both motor-pos-cmd pins = 810
G90 G0 A-0 B-0 => joint.3.motor-pos-cmd = 720, joint.4.motor-pos-cmd = 0.
So it does work. Are you testing with an actual rotary? The wrapped rotary will show 0 on the DRO even though the motor-pos-cmd is 720.
Replied by andypugh on topic Unlimited rotary axis
But when i call c0. it would find closest way to 0 position..
Last edit: 16 Jul 2018 18:55 by andypugh.
16 Jul 2018 18:56 #114330
I just tested it on 2.8.
WRAPPED_ROTARY has to go in the [AXIS] section. (Which I think is probably wrong..)
The following user(s) said Thank You: jsskangas
16 Jul 2018 20:32 - 16 Jul 2018 20:35 #114338
by jsskangas
Magic word was [AXIS] section.
I had it in [JOINT] section.
Yes, Im running Nikken 5ax120, for C axis i need this.
It work as I like it.
Sing determines rotation direction and degrees are from 0 to 360.
With this one I can live with.
Last edit: 16 Jul 2018 20:35 by jsskangas.
Time to create page: 0.071 seconds
