Which mode is best for new setups?
01 Mar 2019 01:29 #127379
by hatch789
Hi Andy, I removed that line by commenting it out but now when I watch the scope after any kind of move with a little speed on my Z, the f-error just floats like a wave up and down up and down continually, never settling out. It's kind of pretty to watch but not so good for CNC work.
I'm going to try something in there like 0.001 maybe?
Replied by hatch789 on topic Which mode is best for new setups?
Which axis is slow? The Z?
Try removing this line from the HAL.
setp pid.z.maxerror .0005
01 Mar 2019 02:06 #127383
by Grotius
Replied by Grotius on topic Which mode is best for new setups?
Hi Christhopper,
Try to google minferror = 0.25
For pid this might solve your problem.
- Thank you received: 1370
01 Mar 2019 03:57 #127387
Replied by Todd Zuercher on topic Which mode is best for new setups?
The hal pin(s) "joint.N.amp−fault−in" is one of the better options for connecting it.
01 Mar 2019 04:29 #127388
by hatch789
Thank you Todd, what would I set my Clearpath to report in this case? I was thinking that position might be nice since then even if I move the Z by hand it will know where it's at. Thoughts, suggestions welcome. I'm still learning on this so I appreciate the guidance.
I got my Z working perfectly though I suspect I need to get the slightly larger motor now. This one keeps squawking at me because of torque saturation. I was worried I might end up having to increase the size... well now I know. I guess I should have just gone with that larger one in the first place. -Live and learn. Now I will have another week delay that I caused myself. /sigh
Here are my HAL and INI files if anyone's interested. I have not yet hooked in the HLFB but I will soon!
Also here's a video of my fully working, now 3-axis machine! 3-Axis Video
01 Mar 2019 12:57 #127407
Replied by andypugh on topic Which mode is best for new setups?
I still think that the pid.z.maxerror value is wrong. It limits your PID output (ignoring FF1) to P * 0.0005 = 0.5mm/sec
01 Mar 2019 15:25 #127427
by hatch789
Andy I had attached my new hal and ini files in my last message and have (as you suggested) commented out that line. Is there another one I'm missing now? I did try increasing it to 0.001 for a quick test but it wasn't the fix; so I have removed it completely as per your original suggestion. The attached files should reflect that unless I'm missing something else you're referring to in my HAL file?
01 Mar 2019 15:27 #127428
I still see
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
01 Mar 2019 15:31 #127429
by hatch789
crap I forgot to run my fix.
Should be identical but the deriv lines and that maxerror are commented out. Sorry! I have a script I run after I do pncconf.
I was testing backlash settings and just forgot to run my fix.sh script before attaching those files.
01 Mar 2019 15:42 #127431
You've probably reached the point where going back and running PNCconfig is a waist of time. Just directly edit the hal and ini files by hand with a text editor.
The config wizards are great for setting up a rough skeleton of a machine configuration. But after that, hand editing is usually the best way to go for fine tuning it and making more specialized setups.
01 Mar 2019 16:21 #127438
by hatch789
Yeah I will as soon as things get beyond what my quick "sed script" can fix. For not it lets me keep things 100% consistent. So I'm still unclear what I'll set in my clearpath motor to output on the HLFB for my input pins into LinuxCNC. It seemed like those pins were just looking for an error indicator but is there a URL someone can point me to for the finer details on this sort of feedback? -I'd like to better understand my options.
