Write movement manualy to g-code with linuxcnc
23 Mar 2019 09:37 #129345
by aleksamc
Write movement manualy to g-code with linuxcnc was created by aleksamc
Hi, all.
I have very interesting task to realize.
On my CNC machine I want to set encoders and to move spindle manualy. And linuxcnc should write this coordinates to file as G-code for each axis. After that I want to open this file and to make run in linuxcnc program.
How can I make this? I know that it's far from default task of linuxcnc - read encoder inputs and write them to the file. Or I need to write my own program in Pyton where I should use HAL only? Please give me an advise of that.
As for hardware I want to use Mesa cards for this. Motors will be controled with analog singal to servodrives.
23 Mar 2019 12:07 - 23 Mar 2019 12:07 #129350
by pl7i92
Replied by pl7i92 on topic Write movement manualy to g-code with linuxcnc
this is called probe result
look into here
there are ready made NGC and functions to probe a part in a boundery
look into here
Last edit: 23 Mar 2019 12:07 by pl7i92.
23 Mar 2019 13:00 #129358
by fixer
Replied by fixer on topic Write movement manualy to g-code with linuxcnc
This is called teach-in on some controllers,
Here is LinuxCNC implementation forum.linuxcnc.org/forum/21-axis/30986-a...osition-logger#74810
Time to create page: 0.161 seconds
