Axis Position Logger
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
18 May 2016 13:06 - 22 Mar 2021 13:12 #74810 by BigJohnT
Axis Position Logger was created by BigJohnT
After playing around with the teach-in script I decided to expand on that thought and created a data logger with more options.
Yet to do is the menu items like Save etc. Anyway I thought I'd share this to see if I get any feedback.
To run make sure postion-logger.py is executable (right click properties) and Axis is running before you start the program.
To Download the file you must right click and select Save As
Also note that this requires GTK2 so run from a terminal the first time to check for import error of GTK.
If you get this error then install GTK2 with sudo apt-get install python-gtk2
Also note that this requires Python 2.
The latest Position Logger is at github.com/jethornton/emclog
JT
Last edit: 22 Mar 2021 13:12 by BigJohnT.
The following user(s) said Thank You: billykid, jo_key, partec, tivoi, marq_torque, aleksamc, Ehsan_R
19 May 2016 20:52 #74866 by marq_torque
Replied by marq_torque on topic Axis Position Logger
Just amazing Sir,
Loved UI, i tried logging axis values all is good good.... only one question, why its not saving any of file name ? or if its saved somewhere then where ? its not asking for any file name or path no display just lying as it is when i give save or save as.. ??
Thanks & Regards,
Ankit
  • BigJohnT
  • Administrator
  • Administrator
20 May 2016 10:57 #74873 by BigJohnT
Replied by BigJohnT on topic Axis Position Logger
JT
The following user(s) said Thank You: partec, marq_torque
  • BigJohnT
  • Administrator
  • Administrator
20 May 2016 11:01 - 20 May 2016 13:04 #74874 by BigJohnT
Here is an update with more functions completed. Feedback is welcome.
Edit: final version
JT
Last edit: 20 May 2016 13:04 by BigJohnT. Reason: Add Final Version
The following user(s) said Thank You: PKM, tommylight, ts14, bkt, tivoi, LearningLinuxCNC, uur.ersan, marq_torque, aleksamc, Cpk_Rbt
23 Aug 2016 19:09 #79329 by Cpk_Rbt
Replied by Cpk_Rbt on topic Axis Position Logger
This is awesome! Good work and thank you!!
  • Moderator
  • Moderator
23 Aug 2016 19:13 #79330 by tommylight
Replied by tommylight on topic Axis Position Logger
I have yet to use it, but it is nice to know.
Thank you very much, JT
  • BigJohnT
  • Administrator
  • Administrator
23 Sep 2018 20:14 #117905 by BigJohnT
I programmed the Position Logger in PyQt4 and added the ability to have an arc between points.
github.com/jethornton/position-logger
I'm working on a version using PyQt5...
JT
The following user(s) said Thank You: chimeno, KCJ
03 Jan 2021 17:32 #193967 by jurod
Replied by jurod on topic Axis Position Logger
Hi John, thanks for program.
My positions loger (from you github.com/jethornton/position-logger) makes error in row the "none" (foto)
Where is an error?
  • BigJohnT
  • Administrator
  • Administrator
05 Jan 2021 00:03 #194094 by BigJohnT
I don't see the error your talking about in the screen shot, can you elaborate a bit more?
JT
  • Moderator
  • Moderator
05 Jan 2021 00:34 #194100 by tommylight
G1 X288.900None81.000............
there is "none" written in the axis values.
Time to create page: 0.702 seconds
