Axis Position Logger
- BigJohnT
- Thank you received: 994
05 Jan 2021 17:46 - 05 Jan 2021 17:51 #194159
by BigJohnT
Replied by BigJohnT on topic Axis Position Logger
Opps, my guess is I've never tested with more than 3 axes... I see the error is in the ui file I'll fix that in the morning.
JT
JT
Last edit: 05 Jan 2021 17:51 by BigJohnT.
- Tady
- Thank you received: 11
05 Feb 2021 09:37 #197715
by Tady
Replied by Tady on topic Axis Position Logger
Great piece of software. I'm in the process of making a 3d printed arm and this is perfect for teaching the arm some sequential moves. The only thing is can a button be added to copy the points over to the axis screen so the user just presses play and the machine executes the points?
Nice work!
Nice work!
- BigJohnT
08 Feb 2021 23:30 #198096
by BigJohnT
Can you test the changes? I don't have PyQt4 on my development PC...
JT
JT
- Tady
09 Feb 2021 07:23 #198125
by Tady
The Send to Axis button is grayed out
- Tady
09 Feb 2021 07:29 #198126
by Tady
Just for the sake of it I commented out
if IN_AXIS:
As expected the button on not grayed but I have an error
AttributeError: 'MyWindow' object has no attribute 'g_code'
Am I running the program wrong? The Log button logs the commands without problems
if IN_AXIS:
- Tady
09 Feb 2021 10:32 - 09 Feb 2021 10:42 #198134
by Tady
I managed to get it working
I changed this
The Position logger needs to be opened with LinuxCNC for the button to work. If you run it in a separate terminal it doesn't work. Maybe because it is a separate process..
And you need to use Gmoccapy if you want to move the machine to log different positions. AXIS does not work, it looks like it is frozen while position logger is open
I changed this
def sendToAxis(self):
gcode = [str(self.gcodeList.item(i).text()) for i in range(self.gcodeList.count())]
#sys.stdout.write(self.g_code.get(0.0, END))
sys.stdout.write('\n'.join(gcode)+"\nM2") # Add M2 to the end so LinuxCNC is happyThe Position logger needs to be opened with LinuxCNC for the button to work. If you run it in a separate terminal it doesn't work. Maybe because it is a separate process..
Last edit: 09 Feb 2021 10:42 by Tady.
- BigJohnT
09 Feb 2021 17:13 - 09 Feb 2021 17:13 #198164
by BigJohnT
Axis in LinuxCNC 2.8 works fine with the position logger running. However sys.stdout.write does not work with Axis.
JT
JT
Last edit: 09 Feb 2021 17:13 by BigJohnT.
- Tady
09 Feb 2021 19:24 #198187
by Tady
I'm using 2.9.. And with the above changes and Gmocappy works great.. It would be better if I didn't need to close the program to publish the gcode but hey that is wishfull thinking
Thank you for the program. In my opinion it should be integrated in LinuxCNC
The following user(s) said Thank You: BigJohnT
- Bari
- Thank you received: 234
11 Feb 2021 21:08 #198441
by Bari
Replied by Bari on topic Axis Position Logger
I just wanted to put this other position logger into the same place for future reference:
forum.linuxcnc.org/41-guis/25849-teach-i...m-generation?start=0
forum.linuxcnc.org/media/kunena/attachments/16368/Teachin.txt
Modified teach-in.py "stripped down the part of the gui and added a hal pin to capture the position"
"It is a HAL module with an input pin which appends to a file the actual position when the input is TRUE. It is intended to be used with an edge detector to trigger it."
The following user(s) said Thank You: tommylight, Tady
- Tady
12 Feb 2021 23:42 #198613
by Tady
Nice!
So you use a halpin to trigger the capture... How do you end the teaching?
Time to create page: 0.131 seconds
