Laser Control using PWM
- Sockheaven
- Topic Author
- Thank you received: 10
26 Jul 2019 14:32 #140656
by Sockheaven
Laser Control using PWM was created by Sockheaven
I finally got around to purchasing a 15Watt laser to play around with and wanted to use the PWM abilities of LinuxCNC to control the intensity.
I have very little experience with LinuxCNC so I've been having a hard time trying to figure out the correct configuration in the INI and HAL files. I found another poster doing something very similar:
forum.linuxcnc.org/10-advanced-configura...pwm-output-for-laser
But in this post and others I've found, the jargon and references are going over my head so I was hoping to get some assistance.
A few questions/comments so far:
1. When I scope the spindle pwm signal the signal goes high before the cutting path starts (presumably to get the spindle up to speed) - but in the case of a laser, i don't want the laser pre-firing as it will etch outside of the desired path. What is the appropriate configuration so that this PWM only starts while the cutting path is active?
2. When I scope the spindle pwm signal, it appears on or off - not actually modulating. While looking at the configuration i realized I have no idea what is defining the spindle speed, I see where to define the path motion when generating the gcode from dxf, but i don't see anything for the spindle - where is this normally defined?
Attached are my current INI/HAL files, any assistance or direction would be awesome.
Thanks!
Paul
Thanks!
Paul
- Thank you received: 5961
26 Jul 2019 14:56 #140659
Replied by tommylight on topic Laser Control using PWM
This might be usefull
forum.linuxcnc.org/10-advanced-configura...mosing-a-pic?start=0
28 Jul 2019 21:11 #140839
Rather than use spindle (M3 / M5) use the G-code analogue outputs (M67):
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m67
M67 takes effect the instant that the next move command starts.
Replied by andypugh on topic Laser Control using PWM
- Sockheaven
- Topic Author
29 Jul 2019 18:09 #140904
by Sockheaven
Replied by Sockheaven on topic Laser Control using PWM
I've seen M67 referenced in a few other threads when I was searching about this topic but I couldn't figure out how to configure that.
Is this something I manually edit in the GCODE file? or is is a configuration in DXF2GCODE? or something within the INI/HAL configuration in LinuxCNC?
I haven't strayed too far off the guided path so far, so I'm finding I don't know quite a bit
29 Jul 2019 20:29 #140918
Does DXF2GCode output spindle speed and on/off?
If it does, and if it can't be changed then you have a choice of
There are probably other ways I have not thought of, too.
- Edit by hand
- Set up an input filter linuxcnc.org/docs/2.7/html/config/ini-co...html#_filter_section
- Re-map M3 / S / M5 to be M67 commands: linuxcnc.org/docs/2.7/html/remap/remap.html
29 Jul 2019 21:16 #140919
In the link i posted above there is dmap2gcode that will output M67 wherever Z values were.
That is very good for raster laser engraving. I also have somewhere the gcodetools modified to output that, but it is a bit of work to search through all my SSD's.
Let me know if you need it.
- Sockheaven
- Topic Author
02 Aug 2019 13:50 #141185
by Sockheaven
Thanks for all the suggestions. After reading through more documentation I think I'm missing a level of experience to make this work.
Has anyone considered making a GUI setup tool for the HAL configuration?
If I skip the PWM for now, and simply want to gate the spindle signal(or any signal for that matter) with when the "cut" happens, can someone help with the HAL configuration?
I've seen the single line examples in the documentation mixed and some full HAL files in other posts and I'm seemingly unable to fill in the gaps :-/
- Sockheaven
- Topic Author
02 Aug 2019 14:11 #141187
by Sockheaven
Further simplifying - to help understand the HAL configuration better - can I get an example of creating a digital output on one of the PARAPORT pins based on when the "cut" is occurring?
- Sockheaven
- Topic Author
02 Aug 2019 18:48 #141219
by Sockheaven
Ok I feel dumb, I see now that by modifying the GCode I can just turn the spindle on/off between each move command.
Ok, I suspect the duration the laser spends at the start/end is longer due to this primitive method, but its far better than it used to be.
So, stating the obvious, i guess I need to create an additiona pwmgen, attach it to a pin, then the M67 command in a GCODE file will magically turn it on?
06 Aug 2019 21:21 #141548
Pretty much.
You could use spindle on/off to enable and disable the pwmgen (there is an enable HAL pin for the pwmgen, but be aware that unless there is a non-zero spindle speed the spindle-on pin does not change state) and then use the M67 output to set the PWM duty cycle. You probably want a fixed PWM frequency.
linuxcnc.org/docs/2.7/html/man/man9/pwmgen.9.html
You might prefer a pwmgen frequency of 0, which enables PDM mode. In fact a very low frequency PDM might give a rather interesting effect with a laser. (As might low-frequency PWM)
Pretty much.
net laser-enable motion.spindle-on => pwmgen.0.enable
net laser-power motion.analog-out-00 => pwmgen.0.value
setp pwmgen.0.pwm-freq 1000
net pwm-pulse pwmgen.0.pwm => parport.0.pin-00-out
Time to create page: 0.183 seconds
