Random toolchanger
01 Sep 2019 09:02 #143766
by DaOne
Random toolchanger was created by DaOne
I am trying to locate some examples or more documentation on setting up a random swing arm style tool changer. Trying to understand how linuxcnc tracks the tools vs pockets? Anyone happen to have a machine config they don't mind sharing?
01 Sep 2019 15:53 #143787
by pl7i92
Replied by pl7i92 on topic Random toolchanger
you can use a random comp its in the config area
where you can set/order to use the arm taking the next free pocket available
BUT in most cases it will be the same as the tool comes from
or are you like okuma placing a chain behind mashines and connect a master tool libary wher multiple mashines can go on the chain and collect
hobbymashines dont usaly chaire tools with other mashines
and non pocketing tools are insert at manual tool change position and given back to Hand
02 Sep 2019 20:58 #143946
It stores which tool is in which pocket in the tool table and saves the tool table on shut down.
just set RANDOM_TOOLCHANGER in the INI file and the old tool will automatically be put in the pocket that the new tool came out of.
Replied by andypugh on topic Random toolchanger
Time to create page: 0.168 seconds
