Setting Laser to be Triggered by M67 and M68
- Thank you received: 5957
16 Dec 2020 21:57 #192201
Not sure, but i think the version of dmap2gcode with that config does not output anything related to Z axis, so that is puzzling.
Replied by tommylight on topic Setting Laser to be Triggered by M67 and M68
That looks like inverted PWM pin/values.It seems like that’s what’s happening. The light areas of the image are really burning the wood no matter what I change the scale to (pwm scale and joint 2 scale) and the areas where it is supposed to be darker are producing a varied output as you’d want, just inverted (this does seem to be effected by the adjusted scale figures).
- AntimatterAnimals
16 Dec 2020 23:18 #192208
by AntimatterAnimals
Replied by AntimatterAnimals on topic Setting Laser to be Triggered by M67 and M68
I’ll have a play around with inverting the pins tomorrow. I can’t remember what order I inverted them and I also can’t remember if I inverted more than one at a time so I’ll go one step at a time. Yeah it’s very strange. I’ll send some screenshots of the file in dmap2gcode and then a video of my machine when I get a chance.
17 Dec 2020 00:02 #192212
My config should have normal pwm on pin 2 and inverted on pin 3
10 Jul 2023 15:49 #275140
by RRicardo
Replied by RRicardo on topic Setting Laser to be Triggered by M67 and M68
Hi Tom
I have updated my plasma table with a chinese ttl laser and follow your threats about M67 so i copy paste and ajust my hal with these lines:
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
setp pwmgen.0.enable TRUE
net analogout motion.analog-out-00 => pwmgen.0.value
net laserpwm pwmgen.0.pwm => parport.0.pin-02-out
I don´t know how but now if i open linuxcnc and simple load file to raster engrave a image the laser doesn´t turn on.
If i set S command to for example S65, then load file and all runs well being the laser in a range of 0 to 65.
During this the S values are not updated but the result is like should be.
What could i do wrong? can you or anybody help?
thank you in advance
I'm running 2.9 with gmocappyfor laser
10 Jul 2023 18:33 #275149
Threats ??? Oh, threads!
Do you have a running base period or base thread?
Are you actually using a parallel port?
Is the port loaded?
Or just upload the hal and ini files here so we can have a look.
Is the port loaded?
The following user(s) said Thank You: RRicardo
10 Jul 2023 19:52 - 10 Jul 2023 19:53 #275154
by RRicardo
Hi again Tom
Base period or base thread? i simply don´t know, sorry.
- Yes i'm using parallel port and loaded
- After messing around, i return to a point now that laser don´t stop between movements, in one point i was almost there but then didn´t backup hal file....
- Atachments here.
Last edit: 10 Jul 2023 19:53 by RRicardo.
10 Jul 2023 20:54 #275159
The attached file has everything spindle but nothing laser, wrong file?
10 Jul 2023 21:25 - 10 Jul 2023 21:25 #275163
by RRicardo
Sorry Tom
Wrong filesHere are the correct ones.
Last edit: 10 Jul 2023 21:25 by RRicardo.
10 Jul 2023 21:39 #275166
Remove all thisThis is still active and taking control of the PWM, so it has to go.
# net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
# net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 0
setp pwmgen.0.scale 100
setp pwmgen.0.offset 0.0
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
10 Jul 2023 21:41 #275167
by RRicardo
Hi Tom
Very thanks!
I will try right now.
When you guys pass by Portugal you are welcome!!!
Very thanks!
Time to create page: 0.105 seconds
