Setting Laser to be Triggered by M67 and M68
- Thank you received: 5956
10 Jul 2023 21:45 #275168
Replied by tommylight on topic Setting Laser to be Triggered by M67 and M68
Maybe, just maybe, next year i might drop by as i owe Filipe from eusurpus.com a few coffees.
When you guys pass by Portugal you are welcome!!!
10 Jul 2023 22:14 #275173
by RRicardo
Replied by RRicardo on topic Setting Laser to be Triggered by M67 and M68
Hi Again Tom
I had to turn on pwmgen.0.scale 100 other wise it keeps always in 100% but i'm in tests and not have a final conclusion.
It seems if i set S75, the all job will run between that range...
But now it starts without laser turned on and only turns on between M67 commands, right!!!
But when i stop or pause job, laser continues on, i have to correct but don´t know how.
Also don´t have feedback in the screen about laser power but it's ok.
I will do some more tests and give feedback.
Thank you
Thank you
10 Jul 2023 22:37 #275176
No idea when i will have time to test this, i have the machines ready in the shop and frankly i can not recall if i already did this. Will check as soon as i can.
In the meantime, give it a try if you feel like it.
Yeah, that does require adding an "and" component and wiring it to PWM output and "program-is-running", then to PWM pin out.But when i stop or pause job, laser continues on, i have to correct but don´t know how.
The following user(s) said Thank You: RRicardo
Time to create page: 0.076 seconds
