- Configuring LinuxCNC
- Advanced Configuration
- Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
- Kasper-001
- Topic Author
- Thank you received: 5
06 Apr 2023 15:53 #268439
by Kasper-001
hello
im trying to setup auto tool measurement
when i put this segment, into the ini.file under [RS274NGC]
it makes the gmoccapy really really slow, and it dos not work
i was following this guide linuxcnc.org/docs/html/gui/gmoccapy.html...uto-tool-measurement
# Enables the reading of INI and HAL values from gcode---
FEATURES=12
# is the sub, with is called when a error during tool change happens, not needed on every machine configuration
# The remap code
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
07 Apr 2023 00:47 #268472
Replied by cmorley on topic Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
Did you add the [PYTHON] section too?
Did you add the abort.ngc file?
Can you run linuxcnc from a terminal and post what it prints?
- Kasper-001
- Topic Author
24 Apr 2023 12:05 #269756
by Kasper-001
Replied by Kasper-001 on topic Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
yes i just tried one more time, and the same happen, very slow loading,
if i attachs the whole config folder can you help me ?
24 Apr 2023 20:45 - 24 Apr 2023 20:50 #269780
by tincho80
Replied by tincho80 on topic Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
unfortunately, I am facing the exact same problem!
I followed the manual precisely: linuxcnc.org/docs/stable/html/gui/gmocca...uto-tool-measurement
Only when I comment out the prolog and the epilog, the gmoccapy-gui starts normal. but of course then, the tool length measurement doesen't work...
So if someone could please help, I would be very happy, too! many THANKS in advance!
Last edit: 24 Apr 2023 20:50 by tincho80.
25 Apr 2023 10:49 #269840
A pause while loading usually occurs when linuxcnc has a path problem with remap.
Under the PYTHON heading those path settings must be right.
25 Apr 2023 10:52 #269841
How we need to see your config files please
- Kasper-001
- Topic Author
26 Apr 2023 17:25 #269987
by Kasper-001
herre is the config folder
27 Apr 2023 22:19 #270086
by tincho80
It's all working now for me! the only missing thing was the postgui.hal file which I had to create and write manually (to fill with the needed content) according to the instructions in the manual (above link "gmoccapy - tool length measurement")
sorry for bothering the forum!
- Kasper-001
- Topic Author
29 Apr 2023 19:17 #270224
by Kasper-001
now i got this, and i don´t know where to put that pin who is missing,
Debug file information:
custom_postgui.hal:11: Pin 'gmoccapy.toolchange-change' does not exist
30 Apr 2023 13:29 - 21 May 2023 12:09 #270307
by tincho80
hm. I am not a pro.
But it might depend on what you defined in the "HAL-section" in your machine.ini file:look, what is written in your "postgui_call_list.hal"-file. Mine looks like this and it works:what ever file you are loading at start up, it should contain the code below.
my postgui.hal is empty. but the custom_postgui.hal should look like the following:[/code]
[/code]
good luck! once it's working, it's a dream! It's worth the effort to fix it!
[HAL]
HALUI = halui
HALFILE = BridgeportCNC-1.hal
HALFILE = custom.hal
HALFILE = vc-p4s.hal
POSTGUI_HALFILE = postgui_call_list.hal
POSTGUI_HALFILE = vc-postgui.hal
SHUTDOWN = shutdown.hal
# These files are loaded post GUI, in the order they appear
source custom_postgui.hal
[code][code]# The next lines are only needed if the pins had been connected before
unlinkp iocontrol.0.tool-change
unlinkp iocontrol.0.tool-changed
unlinkp iocontrol.0.tool-prep-number
unlinkp iocontrol.0.tool-prepared
# link to gmoccapy toolchange, so you get the advantage of tool description on change dialog
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
[/code]
Last edit: 21 May 2023 12:09 by tincho80.
Time to create page: 0.201 seconds
