- Configuring LinuxCNC
- Advanced Configuration
- Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
30 Apr 2023 14:01 #270308
Replied by Aciera on topic Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
the problem is in line 9 of your 'test2.11.hal':
source postgui_call_list.hal
This needs to be removed as it tries to access pins that are not yet available.
- Kasper-001
- Topic Author
- Thank you received: 5
22 Jul 2023 18:27 #276009
by Kasper-001
Replied by Kasper-001 on topic Auto Tool Measurement setup,makes gmoccapy slow and difrent configation,
hey i have moved it around , and replaced line 9 with source custom_postgui.hal
but still get this
Debug file information:
custom_postgui.hal:11: Pin 'gmoccapy.toolchange-change' does not exist
but still get this
22 Jul 2023 20:11 #276015
The line needs to be _removed_.
The point is that having it there in the hal file will try to load gui-pins that are created only _after_ the hal file is executed. Hence the "postgui" entry in the ini file which means "hal file to be executed after the gui is created".
- Kasper-001
- Topic Author
22 Jul 2023 20:24 - 22 Jul 2023 20:25 #276017
by Kasper-001
then i get this
hm2/hm2_7i92.0: registered
creating ladder-state
Found file(REL): ./custom.hal
CANNOT FIND FILE FOR:custom_postgui
Init tmp dir=/tmp/classicladder_tmp_GPq2hi
INFO CLASSICLADDER---I/O Modbus master closed!
extra emc serial data=8, parity=0, stop=1
INFO CLASSICLADDER---I/O Modbus master (Serial) init ok !
Running HAL shutdown script
ERROR CLASSICLADDER- Error initializing classicladder user module.
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/cnc/linuxcnc_debug.txt
and
/home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
cnc@debian:~$
my ini
[HAL]
HALUI = halui
HALFILE = test2.11.hal
HALFILE = custom.hal
HALFILE = custom_postgui hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
hm2: unloading
and
cnc@debian:~$
my ini
[HAL]
HALUI = halui
Last edit: 22 Jul 2023 20:25 by Kasper-001.
22 Jul 2023 20:34 #276018
First thing is to remove this line in your ini:
second please post the content of this file:
- Kasper-001
- Topic Author
22 Jul 2023 20:52 #276019
by Kasper-001
custom_postgui hal removed from ini
# These files are loaded post GUI, in the order they appear
22 Jul 2023 20:57 #276020
Looks ok.
So on startup these two hal files will be executed:
And after the gui is running this postgui-hal file will be executed
custom_postgui.hal
Are you getting any errors on startup now?
custom_postgui.hal
- Kasper-001
- Topic Author
22 Jul 2023 21:02 #276021
by Kasper-001
it startes very slow , and does not look the same
22 Jul 2023 21:14 #276023
Open terminal type:
$ linuxcnc
and choose your configuration in the config picker.
Alternatively try:
$ linuxcnc -l
(That is a lowercase L to load the last used configuration)
Not much to go on. Starting your configuration in a terminal may give you more information in the form of terminal output while the config starts.it startes very slow , and does not look the same
Open terminal type:
$ linuxcnc
Alternatively try:
$ linuxcnc -l
22 Jul 2023 21:22 #276024
Just as a side note as this is probably not the core problem:
I don't use auto tool measurement but looking at your custom_postgui.hal shows all the lines are commented out (ie this will not do anything at all):
# Include your custom_postgui HAL commands here
# This file will not be overwritten when you run PNCconf again
# The next lines are only needed if the pins had been connected before
#unlinkp iocontrol.0.tool-change
#unlinkp iocontrol.0.tool-changed
#unlinkp iocontrol.0.tool-prep-number
#unlinkp iocontrol.0.tool-prepared
# link to gmoccapy toolchange, so you get the advantage of tool description on change dialog
#net tool-change gmoccapy.toolchange-change <= iocontrol.0.tool-change
#net tool-changed gmoccapy.toolchange-changed <= iocontrol.0.tool-changed
#net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
#net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
Time to create page: 0.204 seconds
