lathe tool sensor setup , who's done it ?
31 Jan 2024 11:49 #292061
by foxington
Replied by foxington on topic lathe tool sensor setup , who's done it ?
hello,
Ive already create dry program for my manual toolchange 4 direction tool probe... but not yet tested because I am out off the shop.. should it be working from you point of view?
I do no know have many conditions should be in the row or in the single expresion ... do you know it please?
o<m275> sub
(master tool number)
#<_toolNumberMaster> = 0
(axis reference number)
#<_xAxisNumber> = 1
(#<_yAxisNumber> = 2)
#<_zAxisNumber> = 3
(etc...)
(tool orientation for probing directions)
#<_toolOrientation1> = 1
#<_toolOrientation2> = 2
#<_toolOrientation3> = 3
#<_toolOrientation4> = 4
#<_toolOrientation5> = 5
#<_toolOrientation6> = 6
#<_toolOrientation7> = 7
#<_toolOrientation8> = 8
#<_toolOrientation9> = 9
(default probing stroke)
#<_probingStrokeDefault> = 50.0
(calibration move off stroke)
<_calibrationMoveOffStroke> = 0.5
(move off probe stroke)
#<_moveOffProbeStroke> = 5.0
(reference value of axis - for lathe 1/2 of wanted value - X10 == D20)
#<_xReference> = 24.0
(#<_yReference> = number here)
#<_zReference> = 0.0
(tool orientation low limit)
#<_toolOrientationLowLimit> = 1
(feed of probing)
#<_roughtProbingSpeed> = 500.0
#<_finalProbingSpeed> = 10.0
(tool number)
#<_toolNumber> = #5400
(tool orientation 1 - 9)
#<_toolOrientation> = #5413
(axis in which probing)
#<_probingAxis> = #<P>
(aproximation lenght of probing stroke in UU)
#<_probingStroke> = #<Q>
(actual coordination system)
#<_actualCoordSystem> = #5220
(probing order M275 P1 - Xprobing in default lenght uu)
(probing order M275 P1 Q150 - Xprobing in 150uu)
(probing order M275 P3 q80 - Zprobing in 80uu)
o108 if[#<_probingStroke> LE 0]
#<_probingStroke> = #<_probingStrokeDefault>
o108 endif
o110 if[#<_probingAxis> EQ #<_xAxisNumber> OR #<_probingAxis> EQ #<_zAxisNumber>] (check if your probing order is right)
o120 if[#<_toolOrientation> GE #<_toolOrientationLowLimit>] (check right configuration of tool table)
G94
G91
G49
o130 if[#<_toolOrientation> EQ #<_toolOrientation1> OR #<_toolOrientation> EQ #<_toolOrientation2> OR #<_toolOrientation> EQ #<_toolOrientation6> OR #<_toolOrientation> EQ #<_toolOrientation5]
#<_probingStroke> = #<_probingStroke>
<_calibrationMoveOffStroke> = <_calibrationMoveOffStroke>
o130 elseif[#<_toolOrientation> EQ #<_toolOrientation3> OR #<_toolOrientation> EQ #<_toolOrientation4> OR #<_toolOrientation> EQ #<_toolOrientation8> OR #<_toolOrientation> EQ #<_toolOrientation7]
#<_probingStroke> = -#<_probingStroke>
<_calibrationMoveOffStroke> = -<_calibrationMoveOffStroke>
o130 else
(#########################################call error for the lathe setup)
#<P>=0
#<Q>=0
M2
o130 endif
o200 if[#<_toolNumber> GT #<_toolNumberMaster>] (check which number of tool are already inserted)
o300 if[#<_probingAxis> EQ #<_xAxisNumber>](other tools then master)
G38.2 X-#<_probingStroke> F#<_roughtProbingSpeed>
G1 X<_calibrationMoveOffStroke>
G38.2 X-#<_probingStroke> F#<_finalProbingSpeed>
G0 X#<_moveOffProbeStroke>
#<probingSuccesfull> = #5070
o350 if[#<probingSuccesfull> EQ 1]
#<axisActualProbeOffset> = #5061
#<axisOffet> = [[#<axisActualProbeOffset> + #<_xReference>] * 2]
G90
G49
$ G10 L1 P#<_toolNumber> X#<axisOffet>
o350 else
(#########################################call an error of probing )
(MSG,Probing in X direction error.)
#<P>=0
#<Q>=0
M2
o350 endif
o300 elseif[#<_probingAxis> EQ #<_zAxisNumber>]
G38.2 Z-#<_probingStroke> F#<_roughtProbingSpeed>
G1 Z<_calibrationMoveOffStroke>
G38.2 Z-#<_probingStroke> F#<_finalProbingSpeed>
G0 Z#<_moveOffProbeStroke>
o360 if[#<probingSuccesfull> EQ 1]
#<axisActualProbeOffset> = #5063
#<axisOffet> = [#<axisActualProbeOffset> + #<_zReference>]
G90
G49
$ G10 L1 P#<_toolNumber> Z#<axisOffet>
o360 else
(MSG,Probing in Z direction error.)
#<P>=0
#<Q>=0
M2
o360 endif
o300 endif
o200 else
o400 if[#<_probingAxis> EQ #<_xAxisNumber>] (master tool reference setup for T0 - find to where probe is located)
o450 if[#<probingSuccesfull> EQ 1]
G90
G49
G4 P0.5
#<axisOffet> = [#<_xReference> * 2]
$ G10 L2 P#<_actualCoordSystem> X#<axisOffet>
o450 else
#<P>=0
#<Q>=0
M2
o450 endif
o400 elseif[#<_probingAxis> EQ #<_zAxisNumber>]
o460 if[#<probingSuccesfull> EQ 1]
G90
G49
G4 P0.5
#<axisOffet> = #<_zReference>
$ G10 L2 P#<_actualCoordSystem> Z#<axisOffet>
o460 else
#<P>=0
#<Q>=0
M2
o460 endif
o400 endif
o200 endif
o120 else
(#########################################call an error of wrong configuration of tool table)
(MSG,Probing error. Wrong tool setup in the tooltable.)
#<P>=0
#<Q>=0
M2
o120 endif
o110 else
(#########################################call an error of wrong configuration of #<P> parameter in the macro MDI call)
(MSG,Probing error. Wrong macro call configuration.)
#<P>=0
#<Q>=0
M2
o110 endif
#<P>=0
#<Q>=0
o<m275> endsub
M30
The following user(s) said Thank You: smc.collins
Time to create page: 0.192 seconds
