Second spindle- HAL configuration
- RobotMatic
- Topic Author
- Thank you received: 21
24 Aug 2023 14:02 - 24 Aug 2023 14:13 #278861
by RobotMatic
Second spindle- HAL configuration was created by RobotMatic
I am trying to configure a second spindle to control by pwm an inductor by control of 0-10volt
I have created a second HAL PWM component perfectly to assign to the second spindle. Until here everything perfect.
I understand that spindle.0 is created by Motion
I need to declare spindle.1 and I do not realize how to do it and I do not know if you can perform loadrt spindle?
How can I declare a second spindle ?
thank you very much
thank you very much
Last edit: 24 Aug 2023 14:13 by RobotMatic.
24 Aug 2023 14:32 #278863
by billykid
Replied by billykid on topic Second spindle- HAL configuration
in the ini file you set the number of spindles... if you now have [SPINDLE_0] add [SPINDLE_1]and do two separate configurations.
linuxcnc.org/docs/devel/html/examples/spindle.html
The following user(s) said Thank You: RobotMatic
24 Aug 2023 14:55 #278866
[TRAJ] NUM_SPINDLES
linuxcnc.org/docs/stable/html/config/ini...g.html#_traj_section
And also in the HAL (though this may be linked to the INI)
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
ie, in the HAL you will have either
loadrt motmod num_joints=3..... num_spindles=1...
Or, possibly
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
In the latter case it is all automatic, and only needs to be altered in the INI file, as the HAL values are read-in from the INI.
Replied by andypugh on topic Second spindle- HAL configuration
In the INI, and possibly the HAL.How can I declare a second spindle ?
[TRAJ] NUM_SPINDLES
Or, possibly
- RobotMatic
- Topic Author
24 Aug 2023 15:09 #278868
by RobotMatic
Replied by RobotMatic on topic Second spindle- HAL configuration
THANK!!!!!!
SPINDLES =2 in the .INI file and in the .HAL file :
Motion
pwngen
loadrt pwmgen output_type=1,1
addf pwmgen.make-pulses base-thread
Spindle-0 pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 1166.66666667
setp pwmgen.0.offset 0.114285714286
setp pwmgen.0.dither-pwm true
Spindle-1 pwm
setp pwmgen.1.pwm-freq 100.0
setp pwmgen.1.scale 1166.66666667
setp pwmgen.1.offset 0.114285714286
setp pwmgen.1.dither-pwm true
spindle 0
net spindle-0-cmd-rpm => pwmgen.0.value
net spindle-0-on <= spindle.0.on => pwmgen.0.enable
net spindle-0-pwm <= pwmgen.0.pwm
net spindle-0-cmd-rpm <= spindle.0.speed-out
net spindle-0-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-0-cmd-rps <= spindle.0.speed-out-rps
net spindle-0-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-0-cw <= spindle.0.forward
spindle 1
net spindle-1-cmd-rpm => pwmgen.1.value
net spindle-1-on <= spindle.1.on => pwmgen.1.enable
net spindle-1-pwm <= pwmgen.1.pwm
net spindle-1-cmd-rpm <= spindle.1.speed-out
net spindle-1-cmd-rpm-abs <= spindle.1.speed-out-abs
net spindle-1-cmd-rps <= spindle.1.speed-out-rps
net spindle-1-cmd-rps-abs <= spindle.1.speed-out-rps-abs
#net spindle-at-speed => spindle.1.at-speed
net spindle-1-cw <= spindle.1.forward
Motion
pwngen
Spindle-0 pwm
Spindle-1 pwm
spindle 0
spindle 1
24 Aug 2023 15:39 #278872
by billykid
I also have two spindles, a 24000 rpm vfd and a maximum 5000 rpm pwm for milling but I preferred to keep 2 separate configurations and start the one I need because you have to use different commands for the two spindles. M3 for the first M3 $2 for the second etc
so out of laziness I didn't touch anything
Time to create page: 0.073 seconds
