- Configuring LinuxCNC
- Advanced Configuration
- Knee mill table height; external offset or something else?
27 Nov 2023 15:30 - 27 Nov 2023 15:31 #286625
Replied by Aciera on topic Knee mill table height; external offset or something else?
No, it doesn't work like that with joint limits, you would jog right into the soft limit and then motion will suddenly stop. There will be no controlled deceleration but something more like an e-stop event.
Last edit: 27 Nov 2023 15:31 by Aciera.
- Thank you received: 5944
27 Nov 2023 16:38 #286629
What am i missing here?
Replied by tommylight on topic Knee mill table height; external offset or something else?
All those machines use 2 joints for Y axis, so it does work with joint limits in world mode. Those 2 joints can not be jogged/moved in joint mode, only after homing when it switches to world mode they can be jogged, together, not single joint at a time.Yes when using axis limits it works but I can only rely on joint limits in this case. Are you sure it should work with only joint limits in world mode?
27 Nov 2023 17:33 #286631
27 Nov 2023 17:34 - 27 Nov 2023 17:35 #286632
by m0602232
Replied by m0602232 on topic Knee mill table height; external offset or something else?
Maybe you have same limits in joints and axis if your machines are gantry-style?
Anyway, I summed axis z limits and table encoder position to ini.z.max and -min_limit in postgui, about like how Aciera suggested (pos-fb-limited is the encoder position after limit3 smoothing):
loadrt sum2 count=2
addf sum2.0 servo-thread
addf sum2.1 servo-thread
setp sum2.0.in0 [AXIS_Z](MIN_LIMIT)
setp sum2.1.in0 [AXIS_Z](MAX_LIMIT)
net pos-fb-limited sum2.0.in1 sum2.1.in1
net zmin-switched ini.z.min_limit sum2.0.out
net zmax-switched ini.z.max_limit sum2.1.out
At least after first quick test it seems to be working. If you see any reason why it should not be done like this please tell, otherwise huge thanks to Aciera and other contributors!
loadrt sum2 count=2
Last edit: 27 Nov 2023 17:35 by m0602232.
27 Nov 2023 17:46 #286633
Ok, so what you need to be aware here is that the change in the axis limit settings will only be used by the planner after a queuebuster. This means that during gcode execution the planner will not automatically use the changed limit values as the lookahead may already have finished queueing the gcode for the planner to be ingested.
Since you seem to want to use this when changing tools you may want to remap M6 to include a queuebuster (eg something like 'M66 E0 L0').
I'm not sure if 'M6' already IS a queuebusting operation so you may want to test your setup without actually putting the tool in the spindle during a tool change.
The following user(s) said Thank You: tommylight, m0602232
27 Nov 2023 20:55 #286637
Yeah, had a feeling i jumped into the deep end!
We are using custom kinematics here, so things are a little unusual.What am i missing here?
Time to create page: 0.130 seconds
