Manual tool change + tool lengh touch off
- Online
- Thank you received: 1369
19 Aug 2022 14:47 - 19 Aug 2022 14:48 #250076
Replied by Todd Zuercher on topic Manual tool change + tool lengh touch off
Personally, I would manually probe all the tool holders for a job before starting, set them up in the tool table. and run the job I wouldn't want to mess with probing at each tool change. That way if you are running a job that uses 6 tools and you need to run it 10 times, you are only probing 6 times instead of 60. (Just my opinion and personal preference.)
Last edit: 19 Aug 2022 14:48 by Todd Zuercher.
21 Aug 2022 02:16 #250138
Replied by andypugh on topic Manual tool change + tool lengh touch off
There are lots of ways to work. I find that I do most of my milling in G54 and tool zero just setting the axis (not tool) offsets. But then I do a lot of work just cranking the MPG or using MDI (often in polar coordinates)
It very much depends on the work you are doing, and I am generally making it up as I go along
- tightmopedman9
- Thank you received: 7
28 Nov 2022 02:50 - 30 Nov 2022 23:16 #257815
by tightmopedman9
Replied by tightmopedman9 on topic Manual tool change + tool lengh touch off
Removed due to inaccuracies in my knowledge of tool offsets
Last edit: 30 Nov 2022 23:16 by tightmopedman9.
17 Jan 2023 16:15 - 17 Jan 2023 16:18 #262248
by furynick
Replied by furynick on topic Manual tool change + tool lengh touch off
I made a lot of work on the tool setter/probe, here is the latest version which is working fine with gmoccapy :
Update configuration file (ini)
change.ngc (stored in macros folder)
init_probe.ngc (stored in macros folder)
[MACROS]
MACRO = init_probe
[TOUCHPLATE]
# Touchplate dimensions
OFFSETX = 3.306
OFFSETY = 3.767
OFFSETZ = 6.172
[TOOLSENSOR]
# Absolute coordinates of the toolsetter pad
X = 680.5
Y = 6.0
# Absolute Z start search coordinates, adjust to match the longest tool
Z =-25.0
# Absolute Z height to safely travel to toolsetter
TRAVELZ = 0.0
# Maximum search distance and direction (sign), adjust to match the difference between the longest and shortest tools
MAXPROBE = -25
[CHANGE_POSITION]
# Absolute coordinates of the tool change point
X = 650.0
Y = 100.0
Z = -10.0
[RS274NGC]
# Relative path to macros folder
SUBROUTINE_PATH = macros
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
O<change> sub
;(debug, in change tool_in_spindle=#<tool_in_spindle> current_pocket=#<current_pocket>;)
;(debug, selected_tool=#<selected_tool> selected_pocket=#<selected_pocket>;)
;(debug, current tool z_offset=#5403)
;otherwise after the M6 this information is gone!
#<xpos> = #<_x> (PRINT,save absolute X=#<_x>;)
#<ypos> = #<_y> (PRINT,save absolute Y=#<_y>;)
#<tlo> = #5403 (PRINT,current offset for tool #<_selected_tool>=#<tlo>;)
#<cht> = #<_ini[CHANGE_POSITION]TRAVELZ>
#<chx> = #<_ini[CHANGE_POSITION]X>
#<chy> = #<_ini[CHANGE_POSITION]Y>
#<chz> = #<_ini[CHANGE_POSITION]Z>
#<tsm> = #<_ini[TOOLSENSOR]MAXPROBE>
#<tsx> = #<_ini[TOOLSENSOR]X>
#<tsy> = #<_ini[TOOLSENSOR]Y>
#<tsz> = #<_ini[TOOLSENSOR]Z>
; we must execute this only in the milltask interpreter
; or preview will break, so test for '#<_task>' which is 1 for
; the milltask interpreter and 0 in the UI's
O100 if [#<_task> EQ 0]
O100 return [999]
O100 endif
O200 if [#<_hal[gmoccapy.toolmeasurement]> EQ 0]
O200 return [3] ; indicate no tool measurement
O200 endif
O300 if [#<_hal[gmoccapy.searchvel]> LE 0]
O300 return [-1] ; indicate searchvel <= 0
O300 endif
O400 if [#<_hal[gmoccapy.probevel]> LE 0]
O400 return [-2] ; indicate probevel <= 0
O400 endif
G53 G0 Z[#<cht>] (PRINT,move to travel height)
G53 G0 X[#<chx>] Y[#<chy>] (PRINT,move to change position)
G53 G0 Z[#<chz>]
G49 (PRINT,cancel tool offset)
G92.2 (PRINT,turn off G92 offsets)
M6 (PRINT,real change tool)
O700 if [#<_selected_tool> EQ 99]
G10 L1 P99 Z0 (PRINT,reset probe offset)
O700 else
G53 G0 X[#<tsx>] Y[#<tsy>] (PRINT,move to toolsensor)
G53 G0 Z[#<tsz>]
F #<_hal[gmoccapy.searchvel]> (PRINT,set search speed)
G91 (PRINT,relative move )
G38.2 Z#<tsm> (PRINT,touch sensor)
G0 Z2 (PRINT,release sensor)
F #<_hal[gmoccapy.probevel]> (PRINT,set probe speed)
G38.2 Z-4 (PRINT,touch sensor)
G90 (PRINT,absolute move)
O800 if [#5070 EQ 0]
O800 return [-3] ; indicate probe contact failure to epilog
O800 endif
G10 L10 P[#<_selected_tool>] Z[#4963] (PRINT,set absolute offset for tool #<_selected_tool>;)
G43
O700 endif
G92.3 (PRINT,restore G92 offsets)
G0 X[#<xpos>] Y[#<ypos>] (PRINT,return to where we were in WCS X=#<xpos> Y=#<ypos>;)
; signal success be returning a value > 0:
O<change> endsub [1]
M2
O<init_probe> SUB
(PRINT,Probe init)
G94 (PRINT,use feedrate in units/min )
G92.1 (PRINT,remove G92 offsets)
G90 (PRINT,absolute distance mode)
G49 (PRINT,cancel tool length compensation)
G40 (PRINT,turn cutter compensation off)
G10 L2 P0 X0 Y0 Z0 (PRINT,reset coordinate system)
O100 IF [ #<_current_tool> NE 99 ] (PRINT,tool loaded: #<_current_tool>;)
T99 M6 (PRINT,mount probe)
O100 ENDIF
O101 IF [ #<_metric> EQ 1 ] (PRINT,set probe feeds according to units )
#<fast> = 150.0 (PRINT,selected metric units )
#<slow> = 30.0
#<retract> = 3.0
#<tool_diam> = #5410 (PRINT,tool diameter=#<tool_diam>mm)
O101 ELSE
#<fast> = 6.0 (PRINT,selected imperial units )
#<slow> = 1.2
#<retract> = 0.1
#<tool_diam> = #5410 (PRINT,tool diameter=#<tool_diam>in)
O101 ENDIF
(PRINT,touch plate Z probe)
G38.2 Z[#<_ini[AXIS_Z]MIN_LIMIT>] F[#<fast>] (PRINT,Z probe toward workpiece with error )
G0 Z[#<retract>] (PRINT,retract)
G0 Z-[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 Z-[#<retract>] F[#<slow>] (PRINT,Z probe slowly, got Z probe at #5063)
G10 L20 P0 Z[#<_ini[TOUCHPLATE]OFFSETZ>] (PRINT,set Z offset in current WCS)
G0 Z#<retract> (PRINT,retract)
(PRINT,touch plate X probe)
G0 X-[#<retract> + #<tool_diam>] (PRINT,move in front of touch plate)
G0 Z-[#<retract> * 2] (PRINT,go down by twice retract length)
G38.2 X[#<retract> + #<tool_diam>] F[#<fast>] (PRINT,X probe toward workpiece with error )
G0 X-[#<retract>] (PRINT,retract)
G0 X[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 X[#<retract> + #<tool_diam>] F[#<slow>] (PRINT,X probe slowly, got X probe at #5061)
G10 L20 P0 X-[#<_ini[TOUCHPLATE]OFFSETX> + #<tool_diam> / 2] (PRINT,set X offset in current WCS)
G0 X-[#<retract>] Z[#<retract>*2] (PRINT,retract)
(PRINT,Touch plate Y probe)
G0 X[#<retract> + #<tool_diam>] Y-[#<retract> + #<tool_diam>] (PRINT,move below of touch plate)
G0 Z-[#<retract>*2] (PRINT,go down by twice retract length)
G38.2 Y[#<retract> + #<tool_diam>] F[#<fast>] (PRINT,X probe toward workpiece with error)
G0 Y-[#<retract>] (PRINT,retract)
G0 Y[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 Y[#<retract> + #<tool_diam>] F[#<slow>] (PRINT,Y probe slowly, got Y probe at #5062)
G10 L20 P0 Y-[#<_ini[TOUCHPLATE]OFFSETY> + #<tool_diam> / 2] (PRINT,set Y offset in current WCS)
G0 Y-[#<retract>] Z[#<retract> * 2] (PRINT,retract)
G0 X0 Y0 (PRINT,move to travel height)
G53 G0 Z[#<_ini[CHANGE_POSITION]TRAVELZ>] (PRINT,move to safe travel height)
G53 G0 X[#<_ini[TOOLSENSOR]X>] Y[#<_ini[TOOLSENSOR]Y>] (PRINT,move to toolsensor)
G53 G0 Z[#<_ini[TOOLSENSOR]Z>]
G38.2 Z#<_ini[TOOLSENSOR]MAXPROBE> (PRINT,touch sensor)
#4963 = #5063 (PRINT,store probe trigger Z value)
G53 G0 Z[#<_ini[CHANGE_POSITION]TRAVELZ>] (PRINT,move to travel height)
G53 G0 X[#<_ini[CHANGE_POSITION]X>] Y[#<_ini[CHANGE_POSITION]Y>] (PRINT,move to change position)
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
O<init_probe> ENDSUB
M2
Last edit: 17 Jan 2023 16:18 by furynick.
The following user(s) said Thank You: Vector
17 Jan 2023 16:26 #262250
by furynick
I forgot to explain the workflow, in my case the probe is a straight rod of 3.175mm (1/8in) :
Move manually approximately over the bottom/left corner of workpiece
Hit init_probe in gmoccapy
The probe (Tool 99) is loaded if it's not already
3 axis of touchplate are probed (Z, X and Y)
The probe is then probed on toolsetter and offset in current WCS is stored
Spindle is moved back to change position
M6 remap probe every tool on toolsetter using G10 L10 with previously stored offset value
Any comment is welcome to improve/secure the process
Time to create page: 0.606 seconds
