Using CNC to cut templates and Gaskets?
- yoshimitsuspeed
28 May 2014 06:45 #47424
by yoshimitsuspeed
Using CNC to cut templates and Gaskets? was created by yoshimitsuspeed
I am trying to think of a cheap easy way to cut gaskets and paper templates using my CNC.
I know one option could be to use a small cutter of some sort but I was wondering if anyone had any crazy ideas like some sort of rasor blade type cutter or anything else I may not be thinking of?
28 May 2014 07:01 #47427
Use a drag-knife, as used in vinyl cutters. Something like www.ebay.com/itm/161317117222
I used one in a flatbed plotter to cut out many, many layers of sticker paper to make 3D parts from.
Replied by andypugh on topic Using CNC to cut templates and Gaskets?
- yoshimitsuspeed
29 May 2014 00:00 #47469
by yoshimitsuspeed
Replied by yoshimitsuspeed on topic Using CNC to cut templates and Gaskets?
That's awesome. I was hoping there was something just like that but wasn't sure what I was looking for.
Any idea on the accuracy? Due to the way it casters I would have to imagine it's a little inaccurate but it doesn't trail very far behind so maybe not much?
I will get one of these to play with but if anyone has any other suggestions I'd love to see what's out there.
It looks like any even small laser setup would be pretty pricey. Has anyone found any cheaper options or other workarounds for that?
29 May 2014 00:26 #47471
I think they trail by 0.25mm. If you want a perfectly square corner I think you need to do a 270 degree loop on the waste side.
Moderators: piasdom
Time to create page: 0.069 seconds
