Limit switchs
29 Dec 2019 01:08 #153381
by jeffie-3
Limit switchs was created by jeffie-3
NO or NC? I'm using 5i25 and 7i77.
29 Dec 2019 01:18 #153383
by Leon82
Replied by Leon82 on topic Limit switchs
I don't think it matters. You would invert if it was backwards.
Although mine are both and I made mine nc on the paraport. When I switched to the 7i96 the input light is on except when the switch is pushed. I had to invert my pins If it wasn't soldered I would probably switch it
29 Dec 2019 15:48 #153443
by jeffie-3
Replied by jeffie-3 on topic Limit switchs
Inverting the pins?
29 Dec 2019 15:57 #153445
by Leon82
In the Hal file(or thru the wizard) you reverse the pin so instead of expecting the switch to be closed it expects it open or vise versa.
The following user(s) said Thank You: jeffie-3
29 Dec 2019 16:09 #153447
Replied by PCW on topic Limit switchs
In general NC is preferable for limit/home switches, because a broken wire will
cause a fault rather than possible uncontrolled motion past the physical limits
29 Dec 2019 17:49 #153465
by jeffie-3
O.K. Here is the section in the hal file. I think. Still new and learning.
# external input signals
# --- BOTH-HOME-X ---
net both-home-x <= hm2_5i25.0.7i77.0.0.input-01
# --- BOTH-HOME-Y ---
net both-home-y <= hm2_5i25.0.7i77.0.0.input-02
# --- MIN-HOME-Z ---
net min-home-z <= hm2_5i25.0.7i77.0.0.input-03
# --- MAX-Z ---
net max-z <= hm2_5i25.0.7i77.0.0.input-04
So to reverse the pin. How?
# --- MAX-Z ---
29 Dec 2019 17:50 #153466
by jeffie-3
Thank you for the answer. A good friend did most of the wiring for me. Some of the limits switches are wired NO and some are wired NC. So I will switch them to all NC.
29 Dec 2019 17:53 #153468
by Leon82
Add _not at the end of the line.
That worked for my 7i96. I would think it's the same for all the combos. It will yell at you if it's wrong
# --- MAX-Z ---
29 Dec 2019 18:13 #153471
by jeffie-3
net both-home-x <= hm2_5i25.0.7i77.0.0.input-01_not ?
29 Dec 2019 18:21 #153472
by Leon82
That's all I had to do.
Moderators: piasdom
Time to create page: 0.098 seconds
