Limit switchs
- Thank you received: 5961
29 Dec 2019 21:35 #153511
Replied by tommylight on topic Limit switchs
NC switches should give 12V at the Mesa inputs when not tripped.
Check the wiring.
Check the wiring.
29 Dec 2019 21:43 - 29 Dec 2019 21:44 #153512
Yep and also, inputs must be 12V relative to field power GND = TB2 pin 8 when on
Replied by PCW on topic Limit switchs
Check the wiring.
Last edit: 29 Dec 2019 21:44 by PCW.
29 Dec 2019 21:51 #153514
by jeffie-3
Replied by jeffie-3 on topic Limit switchs
So if I put the meter on each pin. I need to put the GND on pin 8 of TB2? Each one should read 12 volts?
29 Dec 2019 22:00 #153516
by jeffie-3
O.K. GND is different than -5v or -12v
TB1 pin 1 and TB2 pin 8 run to the same terminal and that terminal runs to the negative side of the 5 volt supply.
29 Dec 2019 22:54 #153521
It is not advisable to wire them together, you can use a separate power supply for the TB1 part, or use a USB cable to power it from a spare usb on the PC, or you can power it from the 5I25/6I25/7I92
They can be connected together but you will loose all isolation from the noisy side of the machine.O.K. GND is different than -5v or -12v
29 Dec 2019 23:45 #153530
by jeffie-3
O.K. Thank you. I have both 12 volt supply and 5 volt supply in the machine. I will change that.
31 Dec 2019 21:39 #153635
by jeffie-3
O.K. I have 11.74 volts from TB8 pin 1, TB8 pin 2, TB8 pin 3, TB8 pin 4 to TB2 pin 8. Checked the voltage at the switchs and it is 0.
Check the wiring.
31 Dec 2019 22:00 #153636
Sounds like your switch common is not connected to 12V
31 Dec 2019 22:32 #153637
by jeffie-3
I checked the one side of the switch and the other side ground. There is 11.74 volts.
31 Dec 2019 23:11 - 31 Dec 2019 23:12 #153643
So is there ~12V at the 7I77 field inputs when the NC switches are
not activated (or 12V when NO switches are activated) ?
If not, you have a wiring error.
wiring should be:
+12V field power --> switch common --> switch output --> 7I77 field input
wiring should be:
Last edit: 31 Dec 2019 23:12 by PCW.
Moderators: piasdom
Time to create page: 0.098 seconds
