Retrofitting an 89 Chiron FZ12W aka Igor
20 Aug 2020 20:12 #178865
by anfänger
Replied by anfänger on topic Retrofitting an 89 Chiron FZ12W aka Igor
I am not good with git, but I can upload my files tomorrow.
Cheers Patrick
Cheers Patrick
21 Aug 2020 17:06 #178942
by anfänger
I attached my config.
it is not finished yet and for my machine, so be careful when you use it especially my g code an m files
the ui file needs to be copied in the probe basic folder and waitfor in the $user/bin folder
The following user(s) said Thank You: akb1212
25 Aug 2020 20:09 #179446
by anfänger
Finally done with rewriting my tool touch off scripts. I use the W offset to set the offset for large tools. So I can run them off center and in reverse.
15 Sep 2020 10:09 #182203
by anfänger
Added a new safety feature. I control the if one of the non uses tool changer arm goes down. If it does, the machine estops
It’s done my a python hal module.
16 Sep 2020 19:34 #182459
by Mara2000
Replied by Mara2000 on topic Retrofitting an 89 Chiron FZ12W aka Igor
Hi Patrick,
could you please write me what needs to be changed in INI probe basic file for correctly displays and works in mm units instead of inches? Thanks a lot. Marek
- Online
- Thank you received: 5935
16 Sep 2020 20:40 #182470
Replied by tommylight on topic Retrofitting an 89 Chiron FZ12W aka Igor
Ahoj Marek,
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm <<<<<<<<<here should be mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_LINEAR_VELOCITY = 250.00
MAX_LINEAR_VELOCITY = 2500.00
The following user(s) said Thank You: Mara2000
17 Sep 2020 05:34 #182505
by anfänger
As tommylight said you need to set the linear_units in the INI to mm
Above I attached my whole config for my machine here a link again:
forum.linuxcnc.org/media/kunena/attachme...829/IgorProbe.tar.gz
You need to keep n mind if you want to have the display working in mm you need set set up the whole machine in metric units
17 Sep 2020 14:00 - 17 Sep 2020 14:02 #182547
by Mara2000
Thank you friends! I will try the settings in the workshop evening.
Last edit: 17 Sep 2020 14:02 by Mara2000.
08 Aug 2021 15:22 #217245
by anfänger
Since the Machine is running well except for some minor issues:
mesa card sometimes doesn't answer I din't figure out what's the problem after four or five tries ist works well.
and the Encoders sometimes loose signal, then i'ts time to wiggle some cables and the it works again.
I wil do some milling in the next time, so I addressed some other thing which I disliked. The first LED I added was falling apart, so I added e third of the ones I installed later:
I am happy with that. Last winter the water treatment for the Coolant I attached to the mill froze. So It was time to get a new one. This time It's in the room next to my heater room, so it won't freeze again. And I got a mixer which eases refilling a lot. But I have to carry it to the machine. I think for my hobby workshop it is OK.
And I removed the old tool storage and made new ones on Din rails
and I made me some tool tags, the third version I liked best (left one I found on thingiverse, middle my first try, right ma final version)
This wee I should get some magnets, wich should make the even more convenient ti see what tools are loaded. By just sticking the to the housing.
The tool cart also got an upgrade with two short din rails
Hopefully this will keep me more organized, but knowing me I doubt it a bit.
11 Aug 2021 09:25 #217491
by anfänger
Moderators: piasdom
Time to create page: 0.107 seconds
