Retrofitting an 89 Chiron FZ12W aka Igor
14 Nov 2022 16:01 - 15 Nov 2022 09:13 #256697
by dinamik
Replied by dinamik on topic Retrofitting an 89 Chiron FZ12W aka Igor
Ok, thank you in advance
I don't think there will be any big problems with the reconfiguration since the only the difference is in current and power of engines wich are(180v/DC) and the inputs are analog on both version of regulators? and as far as mechanics, pneumatics and peripherals... I don't see the difference ?
Best regards
Best regards
Last edit: 15 Nov 2022 09:13 by dinamik.
- Thank you received: 5970
14 Nov 2022 19:41 - 14 Nov 2022 22:43 #256714
Replied by tommylight on topic Retrofitting an 89 Chiron FZ12W aka Igor
@dinamik,
Please delete the emain after you get in contact to prevent from bots spamming you.
Or in his language:
Nebojsa, izbrisi mejl adresu kad zavrsis da te ne spamiraju botovi.
Or in his language:
Last edit: 14 Nov 2022 22:43 by tommylight. Reason: typo
The following user(s) said Thank You: anfänger
14 Nov 2022 20:18 #256722
by dinamik
This is http-secure and I assume that the host is on the RH server or I'm wrong?.
In any case thanks moderator.
14 Nov 2022 22:43 #256735
Sorry, i made a typo in your name above, corrected now.
15 Nov 2022 07:11 - 15 Nov 2022 07:15 #256754
by anfänger
Replied by anfänger on topic Retrofitting an 89 Chiron FZ12W aka Igor
Hi you can remove your mail in your post.
I shared my scanned documents provided by Chiron with the machine by dropbox.
I have no current backup of the chirons Hal files on my dopbox.
I can provide the tonight.
BUT they are only working for my machine and are programmed the best I knew then. I used a lot of bash scripts. The could also be done in gcode. But I was more familiar with linux than with machining.
I don't know If I would do it again the same way.
Cheers
Cheers
Last edit: 15 Nov 2022 07:15 by anfänger.
15 Nov 2022 09:12 #256759
by dinamik
I just downloaded the files and thank you very much.
Send me too if you have maybe illustrated schematic for mesa in/out cards to chiron devices like relays,sensors,atc,servos,spidle,end shalters,airblast...
I used Linux 4 a long time ago and unfortunately not for these things ,but cnc management is my profession.
Thank you again and cheers
15 Nov 2022 10:04 #256760
by anfänger
I Didn't draw schematics.
Watt I did was map the connector plugged into the Sinumerik Control to Mesa Bord IO's with a spreadsheet. This is attached in the Data I sent you. I tried to copy the way the Chiron was controlled my Sinumerik drive. And used the connectors with breakout boards to connect to the Mesa boards.
It worked for me. But from my view today, I wouldn't go this approach again. I would wire to the Bords directly and skip the breakout and also change the old relay boards to modern DIN Rail ones.
15 Nov 2022 10:11 #256761
by dinamik
No need for schematic I found everything in Wechslearme und IOs.ods , just send me when you arrive comressed backup.
Regards
Regards
15 Nov 2022 11:02 - 15 Nov 2022 11:11 #256765
by anfänger
Yea sorry this all is/will be a terrible mix of German and English.
Starting with good intentions making it all well documented and in Englisch and then getting lazy
Last edit: 15 Nov 2022 11:11 by anfänger.
16 Nov 2022 17:00 #256871
by dinamik
In Europe, I only found mesa here:
www.welectron.com/#/dfclassic/query=MESA...bdf7c2dd7421b374f166
but unfortunately most of them are OUT OF STOCK
I wouldn't be surprised if Chinese versions of the cards appear at some point in time because they are not available outside the US
Moderators: piasdom
Time to create page: 0.130 seconds
