Deckel Retrofit FP4A
- milutin.zaric
10 Apr 2024 13:41 #297925
by milutin.zaric
Replied by milutin.zaric on topic Deckel Retrofit FP4A
So, while i am waiting for MESA hardware, i have found out that Linear encoders are plugged into Dialog control.
I have found board:
Heidenhain 255 180 ZY. I would prefer this one over EXE unit. My glass scales are Heidenhain LS904. I think this is compatible with the Platine?
I have found board:
12 Apr 2024 16:50 - 12 Apr 2024 16:57 #298082
by RotarySMP
Replied by RotarySMP on topic Deckel Retrofit FP4A
The LS904 output their analog sin waves:
product.heidenhain.de/JPBC/image/HWP.DE/...06-92_ls_804_904.pdf
You will need EXE's to do the A/D conversion before inputting the signal to the Mesa. Whether you use a three axis EXE board like the one you mentioned or three individual ones is only a packaging issue. On my Maho, I had a similar three axis EXE. One channel was dead, and one was unreliable. I now use the one functioning channel, and two stand alone EXE's.
Those three axis EXE boards are three completely separate channels. There is no electrical connection between them, Not even the supply power or ground are common.
Last edit: 12 Apr 2024 16:57 by RotarySMP.
Moderators: piasdom
Time to create page: 0.305 seconds
