Deckel Retrofit FP4A
- Thank you received: 5928
27 Mar 2024 15:37 #296907
Replied by tommylight on topic Deckel Retrofit FP4A
Not an English short, PCW is a member of this forum and owner of Mesa everything, he is extremely helpful, always.
- milutin.zaric
28 Mar 2024 12:11 #296994
by milutin.zaric
Replied by milutin.zaric on topic Deckel Retrofit FP4A
Lol. So not what, but who
anyway, thanks for your proposals. I will check for available combos and see if they can be delivered soon here. I want to start working on machine
- milutin.zaric
28 Mar 2024 12:28 #296995
by milutin.zaric
So, in the end my shopping cart will look like this:
Just one thing is not clear. For which purpose do we use card with FPGA? Sorry, maybe the questions are dummy, but i am noob in this area.
- 7I92TF
- 7I83
- 7I84 sourcing outputs
- 7i85
28 Mar 2024 13:48 #297001
7i92TM would be better as it plugs directly to 7i85 so no cable needed.
FPGA takes care of the complicated stuff like, generating steps, counting encoders, etc, at very, very fast rates.
- milutin.zaric
29 Mar 2024 08:17 #297069
by milutin.zaric
Hi, i got info that 7I77 will be available maybe next week in EU. I dont know if advertising is allowed but there is one european site for MESA boards ordering.
So my question would be, should i keep the combo, or to replace one part with 7I77?
- milutin.zaric
29 Mar 2024 08:22 #297070
by milutin.zaric
Also, what consernes me is that Inputs on 7I77 are sinking. And i think that i have PNP or sourcing sensors on my Deckel?
29 Mar 2024 14:19 #297109
www.eusurplus.com and www.welectron.com are in Europe, Portugal and Germany respectively.
29 Mar 2024 15:22 #297115
Replied by PCW on topic Deckel Retrofit FP4A
Sinking inputs work with sourcing (PNP) outputsAlso, what consernes me is that Inputs on 7I77 are sinking. And i think that i have PNP or sourcing sensors on my Deckel?
- milutin.zaric
29 Mar 2024 15:30 #297116
by milutin.zaric
Yes. I created cart on www.eusurplus.com. But asking should I wait for 7I77 or just go for same combo?
05 Apr 2024 19:03 #297661
by RotarySMP
Replied by RotarySMP on topic Deckel Retrofit FP4A
The reason I choose the five board solution for my lathe, was because I knew I would want multiple smart serial daughter boards. (At least one 7i84, and one, probably two 7i73's). The 5i25 would need a bit of firmware configuring to connect up further SS to it's pinhead connector, to expand beyond the single SS channel of the 7i77, whereas the 7i85 offered 5 SS channels as it's default config.
The Mesa hardware is very flexible, so you can achieve your goals with a number for different cards. I am considering even adding a second 7i84 to the lathe, as I ran out of 24V outputs.
The following user(s) said Thank You: milutin.zaric
Moderators: piasdom
Time to create page: 0.182 seconds
