Newbie trying to set up and test run milling machine
13 Apr 2021 00:10 - 13 Apr 2021 00:18 #205749
by tml
Newbie trying to set up and test run milling machine was created by tml
Hi folks,
I've been working on a CNC conversion for a small bench top milling machine for a while. I've now finally finished up configuring LinuxCNC on my PC, for the Mesa board. Each machine's axis can now be moved, or jogged from the Axis GUI. So everything seems to be in the right working order.
I want to load up a simple test program to see how the machine runs. Is there a simple program sample included in LinuxCNC I can use to do this task? What are the basic steps in getting the machine to operate? I still yet to have any experience with a CNC type machine and its operation, which is what made me decide to do the conversion so I would have a learning platform to practice on.
Last edit: 13 Apr 2021 00:18 by tml.
- BeagleBrainz
- User is blocked
- Thank you received: 570
13 Apr 2021 01:05 #205753
by BeagleBrainz
Replied by BeagleBrainz on topic Newbie trying to set up and test run milling machine
Get your hands on "CNC In the Workshop" by Marcus Bowman and checkout his website
www.cncintheworkshop.com/Home.html
Hi book is pretty much machine agnostic but does included some of the differences between Mach & Linuxcnc. His website also contains download links for articles he has written for MEW.
13 Apr 2021 12:24 #205779
Well, you can run the LinuxCNC logo splash screen, a lot of people do.
The there should be several sample file in your ~/linuxcnc/nc_files directory.
In most cases you will need to home the machine first, then touch-off the axes to set the working coordinates origin.
Replied by andypugh on topic Newbie trying to set up and test run milling machine
I want to load up a simple test program to see how the machine runs. Is there a simple program sample included in LinuxCNC I can use to do this task?.
The following user(s) said Thank You: tml
04 Jun 2021 17:42 #211171
by tml
Replied by tml on topic Newbie trying to set up and test run milling machine
Something I've been thinking about is the backlash compensation. I remember when I went through my LinuxCNC's mill configuration setup, I did put in some value for that to account for the backlash in my machine. My machine use lead screws so there is some small amount of mechanical backlash in all axes.
When I get a g code file processed from a CAD/CAM software like Fusion 360, and run the program on my machine, does LinuxCNC automatically know to compensate for backlash for all the applicable tool paths for improved accuracy? Or do I need to make modification to the g code file for the machine to do that?
04 Jun 2021 19:14 - 04 Jun 2021 19:16 #211173
by OT-CNC
Replied by OT-CNC on topic Newbie trying to set up and test run milling machine
Linuxcnc will compensate not the cam software.
I would remove backlash as much as possible mechanically. If you can't fit ballscrews, split nuts or cast moglice nuts can work okay. I assume even with compensation, pockets will have flats at the quadrant transitions if there is slop in the mechanics.
Last edit: 04 Jun 2021 19:16 by OT-CNC. Reason: added more
06 Jun 2021 22:39 #211367
by BigJohnT
Replied by BigJohnT on topic Newbie trying to set up and test run milling machine
You could generate a facing program using my G code Generator and soon generate a pocket.
gnipsel.com/linuxcnc/gcode/index.html
JT
JT
Moderators: piasdom
