Fehlemann Picomax 100 Retrofit
- Thank you received: 5942
14 Dec 2021 11:07 #229048
Replied by tommylight on topic Fehlemann Picomax 100 Retrofit
You should change your name from begginner to PRO!
15 Dec 2021 21:12 #229165
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
On many stages I am still a beginner, but with the third retrofit comes some experience and confidence. Still struggling with python I don't really know why.
Today I finished the IO's, now only the encoders are missing. And I need to clean and wired the 24V circuit.
And I want to add a main voltage monitoring relay, cause I can switch control and three phase separately. And I want to get an information when I power on linuxcnc and don't have main power on. This will be used after I finished testing.
Looks almost clean now.
15 Dec 2021 22:37 #229170
FYI, all mesa boards with VFIELD have monitoring for it, i had it shown on a VCP panel on all my retrofits.
Upper right corner:
forum.linuxcnc.org/51-ot-posts/35943-pro...xcnc-screenshot-ever
Upper right corner:
16 Dec 2021 06:28 #229180
by anfänger
The 24v are not the issue, but good to know. I am manually switching 400V main power separate from the control power. I just want to see if main power is on.
I usually have main power off while making changes on the vcp. This way I can test most of the functions without it actually moving
16 Dec 2021 11:48 #229187
A relay wired to Mesa inputs will be enough to show if the power is on or off.
Using one of the 4 analog inputs in mode 1 is also an option to get a rough voltage shown but will require more stuff to isolate from 400V rail, or a THCAD to have the exact voltage shown!
16 Dec 2021 13:07 #229190
by anfänger
Thanks, I found a relay used to emergency lighting, it will change if one or more of the phases will fail. It's fairly priced and was quickly delivered I'll give it a try.
18 Dec 2021 06:37 #229384
by anfänger
18 Dec 2021 15:47 #229407
by anfänger
just finished wiring everything up.
then started the control circuit for testing, only to figure out, I installed 12V Power supply instead of a 24V
But Computer and Mesa Boards are running now, and I can start to configure linuxcnc while I am waiting to the power supply
I can prove you wrong !You should change your name from begginner to PRO!
19 Dec 2021 11:16 #229481
by anfänger
20 Dec 2021 19:39 - 20 Dec 2021 19:44 #229568
by anfänger
I've written a user space feedback for the front panel.
every button hat a back light, which I can switch and a four digit segment display.
First test with 0.1 Hz refresh rate. so its easy to have a look at it in hal show. later it will run with a 50 hz refresh rate.
Last edit: 20 Dec 2021 19:44 by anfänger.
Moderators: piasdom
