Alternatives to 7i76
20 Nov 2021 22:08 #227129
by cadpete
Replied by cadpete on topic Alternatives to 7i76
Tommy and Clive,. I have checked both of those already and both no stock.
- Online
- Thank you received: 5954
20 Nov 2021 22:14 #227130
Replied by tommylight on topic Alternatives to 7i76
Eusurplus has 7i76ED in stock, should have sinking outputs, but i am not sure.
20 Nov 2021 22:22 #227131
by cadpete
Great find Tommy. Was looking for the E version not ED. What would I need to change to use ED? Sorry for the newbie question but the design / help all generally seem to be for the E version
- Online
20 Nov 2021 22:43 #227132
It has sinking outputs instead of sourcing ones on 7i76E.
sourcing outputs = the outputs provide +VCC when on, so the relays/solenoids/LED's have a common ground and the Mesa outputs provide the positive voltage when turned on.
sinking outputs = the outputs sink to ground level when on, so the relays/solenoids/LED's have a common +VCC (12 or 24V positive) and the mesa outputs provide GND/ground/0V when on.
48 points of isolated field I/O are provided for general control use including limit
switch and control panel inputs, coolant enable and tool changer control outputs. Isolated
I/O includes 32 sinking inputs and 16 sourcing (7I76E) or sinking (7I76ED) outputs. Inputs
can sense 5V to 32V signals and the outputs can switch 5V through 32V signals.
Maximum output load is 350 mA. Outputs are short circuit protected.
The following user(s) said Thank You: cadpete
- Online
20 Nov 2021 22:47 #227133
Note to self: do not edit long posts !
Here is a video that explains it much better than i do, just ignore the PLC parts and skip to 45 seconds.
26 Nov 2021 22:59 #227703
by cadpete
Thanks for the help. JT has let me know new stock is in so ordered 7i76e this morning. (4am)
22 Jun 2022 16:13 #245604
by deus
Replied by deus on topic Alternatives to 7i76
Hi
I am currently also looking for a MESA 7i76e. So if anybody has any hints where to get one that would be greatly appreciated.
@cadpete - Who did you mean by JT? I am also from Perth, Australia.
23 Jun 2022 22:46 #245735
Replied by andypugh on topic Alternatives to 7i76
JT = mesaus.com
29 Mar 2024 10:01 #297084
by knipknap
Replied by knipknap on topic Alternatives to 7i76
Any hints on where to find a 7i76e (or 7i76eu) now? Both Eusurplus and Welectron are out of stock, plus I've been looking for one on local ads and Ebay for a year with zero success.
29 Mar 2024 10:09 - 29 Mar 2024 10:10 #297087
Could you use a 7i96S ?
eusurplus.com/index.php?route=product/pr..._id=159&search=7i96s
Last edit: 29 Mar 2024 10:10 by andypugh.
Moderators: piasdom
