Alternatives to 7i76
20 Nov 2021 04:28 #227049
by cadpete
Alternatives to 7i76 was created by cadpete
I was all set to get my Mesa 7i76 card but have run into the problem of no stock due to the chip shortage situation. As this seems to be the preferred card option for mill what other options can you suggest. Unfortunately on a relatively tight budget. It would seem the bulk of controllers are MACH3/4 or grbl and not suited to linuxcnc
20 Nov 2021 08:46 - 20 Nov 2021 08:52 #227056
by Clive S
It would be good to state how many input/outputs you need plus any encoders, mpg's, spindle speed control etc.
A mesa 7i76e ( this is the ethernet version of the 7i76) or 7i96 might do the job
Replied by Clive S on topic Alternatives to 7i76
edit: The 7i76 also requires a 5i25 or 6i25I was all set to get my Mesa 7i76 card but have run into the problem of no stock due to the chip shortage situation. As this seems to be the preferred card option for mill what other options can you suggest. Unfortunately on a relatively tight budget. It would seem the bulk of controllers are MACH3/4 or grbl and not suited to linuxcnc
Last edit: 20 Nov 2021 08:52 by Clive S.
The following user(s) said Thank You: cadpete
20 Nov 2021 09:36 #227060
by cadpete
Replied by cadpete on topic Alternatives to 7i76
Sorry Clive. I was talking about the 7i76e. Design not all set in stone but looking at least seperate X,y and z limits,. 0 - 10 v for spindle and room for 4th axis to enable manufacture of gearing. Also looking at auto tool length check and future expansion options.
20 Nov 2021 10:21 #227070
by Clive S
Are you by any chance in the UK. If so I might be able to help.
20 Nov 2021 11:13 #227075
by Hakan
Replied by Hakan on topic Alternatives to 7i76
Check the 7i96, it may be an even better fit than the 7i76e.
- Thank you received: 5954
20 Nov 2021 11:51 #227076
Replied by tommylight on topic Alternatives to 7i76
7i96 does not have 0-10V, but i might be wrong.
20 Nov 2021 13:45 #227083
by cadpete
Born and bred there ( Northampton) but I now live in Perth, Australia! It looks like all of the Mesa boards are out of stock so was thinking along other brands
20 Nov 2021 13:47 #227084
by cadpete
Thanks Tommy,. Unfortunately that board is also 'out of stock's at mesa. It also lacks the 0 - 10 v for spindle
20 Nov 2021 14:11 #227086
by Clive S
It looks like eusurplus.com/ Portugal has the 7i76e is stock
20 Nov 2021 14:26 #227088
Also check
www.mesaus.com
www.mesaus.com
Moderators: piasdom
Time to create page: 0.162 seconds
