Mesa 7I69S Ghost steps
28 Jan 2023 13:56 #263084
by Stefan321
Mesa 7I69S Ghost steps was created by Stefan321
Hello,
here briefly what I have in terms of hardware.
-Intel Nuc
-Mesa 7I96S with 7I85S bit file
-AsdServo
-MAHOI MH600E
Mistake:
Whenever I switch the machine to On, the mouse spins(Laggy). In addition, the axes keep jerking back and forth.
If I deactivate the servos and then switch them on, everything is fine. When I activate the servos, the machine does what it wants.
If the servos are supplied with power but not activated, everything is ok.
I have already tested to connect the servos differently. But it did nothing.
I also went directly to the board with a different LAN cable, no improvement. it can't be because of the shielding.
It also doesn't matter which servo.
In addition, the jerking back and forth is recorded in Linux CNC, so the position is not lost.
Maybe you have an advice
Thank you in advance for the help
greeting
Stefan
-Intel Nuc
-AsdServo
-MAHOI MH600E
Mistake:
greeting
Stefan
- Thank you received: 6268
05 Jun 2023 00:13 #272917
Replied by tommylight on topic Mesa 7I69S Ghost steps
Found this deleted but i see no reason for it.
05 Jun 2023 13:58 #272943
Replied by PCW on topic Mesa 7I69S Ghost steps
Is this a system with encoder feedback?
Can you post your hal/ini files?
07 Jun 2023 22:16 #273123
by cakeslob
Thats makes this thread even more spoooky
Replied by cakeslob on topic Mesa 7I69S Ghost steps
Moderators: piasdom
Time to create page: 0.148 seconds
